91 F350 7.5 power steering is out.
08-27-2014, 04:22 PM
There isn't much else it could be...
When you remove the old one, clean the frame rail and check for cracks behind it.
08-27-2014, 04:24 PM
on
The entire drivers side is caked with old fluid where the previous owner got carried away with fluid. Ill have to do some pretty hefty cleaning.
08-27-2014, 04:26 PM
better than finding the frame rail is cracked after you get the box in and try to align it.
08-30-2014, 04:39 PM
on
Turns out the box was the culprit. Now I just wish I had marked the position of the steering shaft where it slips onto the box. Not turning left near enough to make a turn now.
08-30-2014, 05:27 PM
It's not the steering shaft, it's the pitman arm.
Point the wheels straight ahead.
Pop the arm off the box.
Center your steering wheel (mine is 3 turns lock to lock IIRC...)
Lock the wheel straight ahead with the ignition.
Put the pitman arm back on in the nearest spline.
08-30-2014, 06:42 PM
on
The box I got came with the pitman arm on it already. couldnt get it off so just left it alone.
08-30-2014, 06:54 PM
This is a problem because it is the box that is limiting turning.
Did the box come from a similar year F-350?
on
I believe it came off a 88 or 89 3/4 ton.
08-30-2014, 06:57 PM
Pretty sure the TTB 250 uses a different pitman arm.
08-30-2014, 06:59 PM
on
I couldnt get the pitman arm off, so I just used it. Only difference was a 1/4-1/2 inch rise.
08-30-2014, 07:04 PM
Well, good luck.
Let us know when you get it fixed.
08-30-2014, 07:24 PM
350 pitman on a 250 will work, it bumps the stops a little sooner is all. A 250 pitman on a 350 isn't worth a crap, you can't turn a circle in a 40 acre field!
08-30-2014, 07:27 PM
on
I broke 2 pitman arm pullers trying to get it off. So I dont really know what else I can do without breaking out a cutting torch. May just have to plan ahead and try not to need to turn sharp to the left from now on.
08-30-2014, 07:29 PM
I don't know how you can break a puller.
Just put some pressure on it and hit the collar of the arm hard with a 3 or 4 pound hammer.
08-30-2014, 07:32 PM
on
First one the bolt stripped all the threads out, the second developed a crack on the arm. They were the el cheapos from Oriellys . I may call in professional help to see if I can get it loose and put the original arm on it.
