Turns out the box was the culprit. Now I just wish I had marked the position of the steering shaft where it slips onto the box. Not turning left near enough to make a turn now.
It's not the steering shaft, it's the pitman arm.
Point the wheels straight ahead.
Pop the arm off the box.
Center your steering wheel (mine is 3 turns lock to lock IIRC...)
Lock the wheel straight ahead with the ignition.
Put the pitman arm back on in the nearest spline.
350 pitman on a 250 will work, it bumps the stops a little sooner is all. A 250 pitman on a 350 isn't worth a crap, you can't turn a circle in a 40 acre field!
I broke 2 pitman arm pullers trying to get it off. So I dont really know what else I can do without breaking out a cutting torch. May just have to plan ahead and try not to need to turn sharp to the left from now on.
First one the bolt stripped all the threads out, the second developed a crack on the arm. They were the el cheapos from Oriellys . I may call in professional help to see if I can get it loose and put the original arm on it.
