'54 COE anyone? - Ford Truck Enthusiasts Forums
'54 COE anyone?
Old 08-22-2014, 05:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
'54 COE anyone?
Just back from a trip and ran across this interesting COE in Seneca, KS. It's for sale ($2500) and has a fair amount to recommend it.
48k miles showing, it was a farm truck so that could be actual total miles
Has a later FE engine, exact details unknown to owner/seller), with a 4-barrel autolite carb. It has run well enough to drive around the block, but I didn't hear it.
12v
Stock trans (it appears)
Two-speed rear axle
Rear wheels are tubeless 20", NOT WM's; fronts are WM's
Has hydroboost brakes and they are all working but RR has a leaking cylinder.
Hydraulic dump box works
Interior had mice, seat cushions are shot. Headliner missing.
All the sheet metal is there and relatively rust-free. There is a hole in the door jamb at the floor, that needs to be fixed.
All in all, for the money it looks like a deal to me. The seller doesn't "do" internet much, so if you're interested, give Mark a call at 785 336 1079
Old 08-22-2014, 05:13 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
Wish I didn't have so many projects going on right now, that would be one heck of a cool project. Thanks for posting Ross. Someone should ****** that up.
Old 08-22-2014, 05:14 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Cool truck. The FE transplanted in there looks like it belongs. It'll make someone a fun project.
Old 08-22-2014, 05:23 PM
ALBUQ F-1's Avatar
postin' fool
The camera didn't really capture it, but the carb inlet is darn near as wide as the tunnel, so the air cleaner was cut on both sides to fit. The fan was mounted on a custom bracket, very well done, so it can use the stock radiator and shroud.
Old 08-22-2014, 06:20 PM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Very nice! And a dump bed to boot.
I don't like that suggestion on the windshield however: "Make a cool ratrod."
Old 08-22-2014, 06:39 PM
ALBUQ F-1's Avatar
postin' fool
A ratrod to him was (for example) making it into a lowered, F-1-sized pickup, like 48FordCOE's.
Old 08-22-2014, 08:10 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
A great start to a project! Bet it was fun cramming that FE in there.......oddly, I've seen several of those COE's with an FE transplant.
Old 08-22-2014, 11:23 PM
frankcowan's Avatar
frankcowan frankcowan is offline
frankcowan is starting off with a positive reputation.
That's a nice truck and a good deal. They did a good job fitting that FE. If it was 1000 miles closer.
Old 08-23-2014, 12:00 AM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
That would be nice to have that's for sure. Someone needs to pick that up. I wish I could.
Old 08-23-2014, 12:34 AM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
That is a nice truck. Usually the lower part of the hood gets rusted out on these years.
Old 08-23-2014, 12:55 AM
pweng1's Avatar
pweng1 pweng1 is offline
pweng1 has a good reputation on FTE.pweng1 has a good reputation on FTE.
If it were closer to me id have it but then it wouldnt be so nice here in rustville
Old 08-23-2014, 04:18 AM
Aus56's Avatar
Aus56 Aus56 is offline
Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.
That seems a pretty good price considering what they cost in OZ
1953 Ford COE CAB Over V8 Flat Head HOT ROD Custom F150 F250 F350 | eBay
1948 Ford Cabover F100 V8 Flat COE Patina F150 F250 Chevy Best IN OZ Harley | eBay
They are few and far between here I think, as most of these old trucks are generally, especially pickups. Some of the bigger stuff is around, big flatbeds and tractors as I believe you call them, or prime movers here.
Old 08-24-2014, 09:28 PM
04KingRanch's Avatar
04KingRanch 04KingRanch is offline
04KingRanch is starting off with a positive reputation.
The truck is every bit as good as it was described. I literally live six miles down the road from this truck and if it is still there after a good harvest it will be sitting in my barn. A lot of farmers in this community are very handy with wrenches, usually while enjoying some spirits, and they do quality work. From what I can tell I can attest to how clean it is. I have not gotten to drive it yet, but I am hoping for a rainy day to stop up and take her for a spin if possible. It will be five weeks until I would be able to reel her in, so this is everyone's warning.
Adam
Old 08-24-2014, 09:38 PM
Harrier's Avatar
Adam, I hope you can work everything out to get it.
Then you will have to join us on the forum and post lots of pictures.
I will warn you however, one you get one of these, the sickness starts. Your friends and family may think something is wrong with you, but we will help you through the transition. We will show you not only how to survive this disease, but how to thrive with it.
Old 08-27-2014, 09:59 AM
vintage56's Avatar
vintage56 vintage56 is offline
vintage56 is starting off with a positive reputation.
holy smokes. that truck looks solid!
as usual, opportunity and fun-funds never align...
otherwise, I'd be snagging one out from under you Adam!
5 weeks? you're probably safe.
probably...
JML
Near clemson? GG150 South Carolina Chapter 3 09-19-2016 05:51 PM
54 COE for sale Slowpoke Slim Large Truck 1 05-14-2016 12:20 PM
Stormfinder's Super Slow Build Thread Stormfinder Excursion - King of SUVs 29 03-08-2015 08:18 PM
1948 Ford Coe 48fordcoe Vehicles for Sale 2 11-20-2014 04:54 PM
1972 f350 dump bed seneca87 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-10-2010 08:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
