Stupid OBS Question - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Stupid OBS Question
Old 08-22-2014, 04:26 PM
tractoman's Avatar
tractoman tractoman is offline
tractoman is starting off with a positive reputation.
Stupid OBS Question
I need to remove a fuel door to bring in for a paint match. How do you get these little devils off? Do I have to try and remove the bolts while the door is open through the little gap or can I get the pin and spring off the hinge and get the door off?
Old 08-22-2014, 06:31 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Unbolt the door from behind. (2) 11mm nuts
2011 f250 ext cab door panel removal Bladely 1999 to 2016 Super Duty 0 03-26-2012 04:53 PM
door panel/door removal 88 f-250?? bigmacmonday 1987 - 1996 F150 & Larger F-Series Trucks 6 06-16-2010 04:59 AM
Door Panel Removal Bluze 1987 - 1996 F150 & Larger F-Series Trucks 11 02-06-2009 02:47 PM
2003 Ford Ranger extended cab rear door pannel removal? chronos Ranger & B-Series 14 01-19-2007 01:35 PM
Remove DS interior door panel with door closed mahanson Explorer, Sport Trac, Mountaineer & Aviator 1 09-08-2006 10:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
