97 zf5 grinding - Ford Truck Enthusiasts Forums
97 zf5 grinding
Old 08-22-2014, 03:14 PM
onepieceatatime16 onepieceatatime16 is offline
onepieceatatime16 is starting off with a positive reputation.
97 zf5 grinding
I've got a 97 350cclb with a 5 speed and I've only had it for about 3 months. It's got 350,000 miles and I think the original tranny. When I try to downshift or go into gear from coasting it grinds. Especially with 3rd. It grinds when going into 3rd at 12mph. I need some opinions on what I should replace in order to get my truck shifting good.
Old 08-22-2014, 05:25 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
I understand that the quite down after they break in lol. My truck does the same thing. The syncro a in it are on there way out or already gone. I double clutch when I shift. Some guys have had good success with amsoil syncromesh but I've never tried it.
Old 08-22-2014, 06:02 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
FIRST thing to check is clutch actuation. Start with measuring the fork travel right at the end, while an assistant works the pedal. Should be at least 1/2" travel.
What fluid are you running in it, and how's the level?
Old 08-23-2014, 04:21 PM
Leatherneck007's Avatar
Leatherneck007 Leatherneck007 is offline
Leatherneck007 is starting off with a positive reputation.
maybe you need a new clutch
Old 08-23-2014, 04:38 PM
Quote:
Originally Posted by madpogue View Post
FIRST thing to check is clutch actuation. Start with measuring the fork travel right at the end, while an assistant works the pedal. Should be at least 1/2" travel. What fluid are you running in it, and how's the level?
I'd be amazed if it was the clutch. It's worth a look but being the gear most shifted through id say synchros. If it was hard to get into gear at a stop then definatly the clutch.
Old 08-24-2014, 01:23 AM
Yeah it's at the very end of the shift while going into gear, which I believe means it's the synchros
Grinds into 5th gear tananaBrian 1999 to 2016 Super Duty 12 10-09-2015 05:51 PM
grinding when shifting to second 1992FordF150Custom 1987 - 1996 F150 & Larger F-Series Trucks 10 05-22-2013 11:11 AM
Help diagnose my ZF6 LSO1123 1999 - 2003 7.3L Power Stroke Diesel 7 11-22-2011 07:35 AM
what causes reverse to pop out/grind on ZF5? boggerted 1987 - 1996 F150 & Larger F-Series Trucks 8 04-14-2010 09:03 PM
F-350 5-speed manual trans grinds into 2nd gear when downshifting?? shad9876 1987 - 1996 F150 & Larger F-Series Trucks 4 07-25-2008 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
