Ecoboost overheat - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Ecoboost overheat
Old 08-22-2014, 04:00 PM
basecamp basecamp is offline
basecamp is starting off with a positive reputation.
Ecoboost overheat
Curious if anyone has found a solution to the F150 ecoboost overheating issue. I have 2013 ecoboost max tow. Last summer and this summer if I climb a long hill, the temps rise and I have to back way out to let it cool off. Dealer still says Ford has no solution. Feel like I am chasing my own tail on this one. I tow about 9000lbs so well within my tow ratings.
I love the truck in every other way. Great power. Decent mileage for having the max tow. And comfortable.
Old 08-24-2014, 07:00 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Ours is not a truck, but never have an overheating issue, even here in texas...
only towed my utility trailer and lawn tractor with it once, so not a big load to test...
good luck, maybe add water injection for those few times you need it ?
give these guys a call to see what would be right for you --> http://www.snowperformance.net/ford-...l-other-models
Old 08-24-2014, 03:53 PM
MCDavis's Avatar
MCDavis MCDavis is online now
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Did the truck cut back on power, or did the dummy gauge just peg?
What trans temps were you seeing during these pulls with that weight behind you?
Old 08-25-2014, 09:17 AM
Trans temp always stays between 205 to 225. The dummy gauge pegged and then the notice of reducing power to cool engine come on. I also am able to watch the temp with a scanner and the engine hit 240 when the reducing power notification came on.
Old 08-25-2014, 10:41 AM
MCDavis's Avatar
Seems like you've got a good eye on it. What speeds and grades are you pulling?
Old 08-25-2014, 10:48 AM
It is a max of 7% grade. I think it goes for about 7 miles. I pull it at 65 mph. The truck pulls it very well, It seems like the last mile is when it finally gets hot. Gauge doesn't move then once it does it climbs quick.
Old 08-25-2014, 11:42 AM
MCDavis's Avatar
7% for 7 miles is a GOOD CLIMB. I hate to say it, but you may need to bring the MPH down 5-10 on that pull.
Old 09-04-2014, 09:35 AM
jwhitetail jwhitetail is offline
jwhitetail is gaining momentum as a positive member of FTE.
I would look for boost leaks, bugs clogging the rad flow, and change the thermostat to a 170, 240 is hot even in a diesel. Thermostat could be not opening all the way.
Old 10-07-2014, 06:43 PM
Flea's Avatar
Flea Flea is offline
Flea is starting off with a positive reputation.
Any update on a fix for this issue?
Old 10-09-2014, 05:37 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.conger is gaining momentum as a positive member of FTE.
It's too bad they are not mechanical gauges. It's seems like the electronic one don't react until it's almost too late. It would also be nice to keep an eye on boost and EGT. Important things with turbocharged engines as far as I'm concerned.
I know you said your truck has Max tow package. But there are some different option levels up to the 11300 lb trailer weight. Have you done the calculations to find out if your truck is near its maximum trailer weight? There is a chart from Ford and you look it up based on you model, axle ratio & engine.
Mine is a 2013 screw 4x4, eco and 5 1/2' box. Max tow pkg with 3.73 eld axle and the chart says biggest trailer loaded for me is 9460 lbs.
Bigger rating would come with 4.10 axle and 6.2 engine.
If I were in your shoes I might look at a higher performance water pump (if anyone makes one) or perhaps bigger radiator. (also big job with an ecoboost)
Your might find the parts you need through Ford racing?
Let us know how it turns out.
Ecoboost for short trips idealtrucks 2009 - 2014 F150 14 01-11-2017 12:34 PM
2013 F150 Ecoboost Max Tow question jokerb19 2009 - 2014 F150 29 07-15-2016 07:05 PM
Mountain towing with Ecoboost Edwardo43 Toy Hauler Towing; Fifth Wheel & Bumper Pull 13 04-25-2016 09:37 PM
eco boost gas econ on towing Rickyrobert 2009 - 2014 F150 20 04-11-2015 05:19 PM
ecoboost limmt for towing. Rickyrobert 2009 - 2014 F150 3 04-05-2015 05:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
