05+ dana 60 outer dust sleeve?
Just clean the axle tubes if you ever have to reinstall axles to prevent dragging the axle end through grit and possibly damaging the inner axle seals which will cause gear oil to leak. The outer axle seals will not contain oil that leaks past the inner seals even when they are new. They are just to keep some dust out of the tubes. The older model axle housings did not have these outer seals. You don't have to do all the work required to remove axles just to replace these outer seals. You can do them when you replace hub bearings or ball joints which will be soon enough.
monster79f150
09-02-2011 07:28 PM
jbarefoot
04-06-2011 11:45 AM
ivanribic
08-27-2005 01:42 PM
