05+ dana 60 outer dust sleeve? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-22-2014, 03:59 PM
Greg5OH Greg5OH is offline
Greg5OH is starting off with a positive reputation.
I hear the outer dust sleeve (at the end of the axle housing) comes loose all the time. Well, both mine are loose and dangling.
Can i sandwich these back in without removing the whole knuckle? Is there a trick to get em to stay in?
Old 08-22-2014, 04:39 PM
Modularation Modularation is offline
Modularation is starting off with a positive reputation.
Just clean the axle tubes if you ever have to reinstall axles to prevent dragging the axle end through grit and possibly damaging the inner axle seals which will cause gear oil to leak. The outer axle seals will not contain oil that leaks past the inner seals even when they are new. They are just to keep some dust out of the tubes. The older model axle housings did not have these outer seals. You don't have to do all the work required to remove axles just to replace these outer seals. You can do them when you replace hub bearings or ball joints which will be soon enough.
Old 08-22-2014, 05:00 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
fyi..if you get new ones they have updated the part now. likely you won't have to replace them once you buy the updated part.
Old 08-25-2014, 09:58 AM
thanks. When I do BJs (hopefully not for a little while) ill ge tthe new ones then.
Old 08-25-2014, 10:49 AM
Iron2 Iron2 is offline
Iron2 is starting off with a positive reputation.
Here is the updated part number for the axle seals.
AC3Z-1S175-A (BRS-170)
05 loose axle seals. Greg5OH 1999 to 2016 Super Duty 11 09-06-2015 01:20 PM
Rear leaf spring bushing outer sleeve removal BGF100 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-29-2015 08:51 PM
Replacement parts dougcepress 1999 to 2016 Super Duty 2 04-21-2015 06:26 PM
Highboy steering control valve question n9lhm 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-07-2014 11:03 AM
Changing Ball Joints........Need Seal Info DSMMH Excursion - King of SUVs 4 06-19-2014 01:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
