You won't believe this! - Ford Truck Enthusiasts Forums
Old 08-22-2014, 10:14 AM
DSMMH's Avatar
DSMMH DSMMH is offline
DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.
Three weeks ago, I'm on my way to work. Mileage to work is 15 miles one way, about 20 minutes travel time and the OAT was 68. 120,000 miles on the clock. Initially, after about 3 miles, I noticed no heat to get the fog off the windshield. Temp guage was moving but not like normal. Figured it was a heating system problem. Got about half way to work and the fan goes roaring. Looked at temp guage and it was not normal and was below where it normally is. Guage never got to normal operating temp. Had 4 stop lights to contend with and the fan is still roaring with no overheat condition indicated. When I got to work, I raised the hood and I could feel the heat. Saw a small amount of fluid on the ground. Looked under the front and the lower radiator hose was completely off. WOW! No coolant in the radiator or about half the motor. I thought the motor was toast. Let it cool down for 4 hours and filled with water. Started right up. Sounded normal. Drove home and everything was normal. Well, almost everything. About 5 years ago I studded the motor but did not change HGs and I had a slight puking issue before I studded the motor. All was good for about a year then I had a slight puking issue show up. As long as I did not stand on it and kept the coolant just so I could see it in the tank, when cold, it would not puke. Plus I would see a constant 20 lbs radiator pressure, even after the motor set overnight. So I had a slight HG leak that was manageable.
After running the motor hot, I no longer have a HG leak. The high engine temperature, experienced during that trip, finally sealed the HGs. No more puking, the radiator pressure lowers to zero overnight and my EGT is about 150 lower than normal. The motor runs great. My big concern was did I fry the FI seals. No indications yet.
I attribute the motor surviving and not coming apart to 5 things: it was a cool morning, the fan did what it was suppose to do, no sustained high speed driving (above 60 MPH), 14.5 quarts of Royal Purple 20W-50 synthetic oil and 1 quart of Archoil 9100 friction modifier. The transmission did not suffer any damage as it has 22 quarts of Royal Purple synthetic ATF (+4.5 quart deep pan) and 35 ozs. of 9100 friction modifier.
Will let you know if things go south.
Ed
Old 08-22-2014, 10:27 AM
Per4mance's Avatar
Per4mance Per4mance is online now
Per4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to all
You EGR cooler delete? and I would get anti freeze back in
Old 08-22-2014, 08:16 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
The motor will officially melt and distruct at 350 degrees. If you stay below that they may survive. I wouldn't test that theory to many times though.
Old 08-22-2014, 10:22 PM
BryanStein BryanStein is offline
BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.
You gotta love when they fix themselves..... It don't happen much.
Old 08-23-2014, 03:13 PM
4x250cx 4x250cx is offline
4x250cx is starting off with a positive reputation.
at sea on a boat we call it he F/M factor,a boaters best friend
Old 08-25-2014, 08:18 AM
DSMMH's Avatar
Quote:
That was the wierd thing. When the lower hose comes off a lot of coolant drains. I assume about half. With what coolant that was left in the motor, I thought it would make steam and send the temp guage out of sight. Niether the water or tranny temp guages went full max. In fact they never reached operating temp during the whole trip.
Ed
**UPDATE** Installed ARP Studs Without Removing the Cab or Motor or HVAC unit DSMMH 6.0L Power Stroke Diesel 23 11-28-2014 07:01 AM
2014 F-350 6.2L Royal Purple Recommendations weluv 6.2L V8 8 10-05-2014 11:14 AM
Blown head gasket symptoms. brickie 6.0L Power Stroke Diesel 16 07-29-2012 08:43 AM
Royal Purple Synthetic Gear Lube in Rear Axle DrFord Oil & Lubrication 18 03-22-2010 12:47 PM
big block overheating in traffic cactusflower Cooling, Heating, Ventilation & A/C 3 09-17-2005 06:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
