Factory rim question - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 08-22-2014, 10:11 AM
Culvert Culvert is offline
Culvert is starting off with a positive reputation.
Hey Guys,
I have a question on what factory rims will fit a 2013 Ford Edge Sport.
We had an Edge limited with 18" facotry rims. I have an excellent set of Toyo G02 winter tires on them & want to know if the 18" factory rims will fit a Sport model with 22" rims?
Bolt spacing is the same but Ive been told the hub center may be different. Anyone that can confirm this?
Thanks Mark
Old 08-22-2014, 12:27 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
center bore should be the same, shouldn't be an issue. I will measure the center bore of the 18" wheel this afternoon and post what it is for ya
Joe
Old 08-22-2014, 01:51 PM
Thanks. I found the info online.
Both 18" & 22" rims have a 70.5 bore. Only difference is the offset spacing 39 on 18" rim. 44 on 22" rim.
Old 08-22-2014, 02:07 PM
Maltman's Avatar
ok, cool
I wouldn't worry about less than 1/4" BS change...should be good to go!
Joe
can a 17" rim fit on a 2012 F-350? Byron West Brakes, Steering, Suspension, Tires, & Wheels 0 10-21-2015 05:18 AM
F350 tires SavO49 1999 to 2016 Super Duty 2 07-04-2014 08:52 PM
Rim Size question JR2980 Excursion - King of SUVs 2 05-25-2014 02:29 PM
Rim question for 2014 F250 supercab txjfrosty 1999 to 2016 Super Duty 2 03-16-2014 02:32 PM
can I do 17 inch rims for snow tires? (factory 18 inch rims) the Goat 1999 to 2016 Super Duty 20 08-27-2010 11:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
