Tank pic request - Ford Truck Enthusiasts Forums
Tank pic request
Old 08-22-2014, 08:00 AM
RL250's Avatar
RL250 RL250 is offline
O/O Desert Rat Customs
RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.
Tank pic request
I am considering injecting my 400 in my 81. I talked to the company I'm looking to procure the EFI kit from about fuel supply. We agreed it would be best to swap in some later model tanks with electric fuel pumps. My question is more of a request. Does anyone have any good shots of the fuel pump setup on the injected gas trucks? I want to know where the pump is and how hard it would be to change out. I also want to keep the dual tanks.
Thanks in advance
Old 08-22-2014, 08:46 AM
joegeds joegeds is offline
joegeds is gaining momentum as a positive member of FTE.
Here's some pics from SuperMotors website. He lifted his bed and replaced the tanks/FDM's. The pics of the FDMs and tanks are about halfway down:
1995 Ford F-150 Junker pictures, videos, and sounds | SuperMotors.net
Old 08-22-2014, 08:58 AM
RL250's Avatar
That helps. It looks like the pump is accessed through the top and completely submerged. Am I looking at that wrong or not?
Old 08-22-2014, 09:04 AM
Quote:
Nope, you are not looking at it wrong. The FDM is the "Fuel Delivery Module" and consists of the pump and the sending unit. It hangs inside the tank. Here are a few pages from my 96 service manual that might help:
Old 08-22-2014, 02:11 PM
RL250's Avatar
What kind of flow are these FDM's rated for in, say, a 460?
Old 08-22-2014, 02:17 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
You can use an aftermarket external pump...
Old 08-22-2014, 02:55 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Agreed. Keep It Simple Stupid
Old 08-22-2014, 05:16 PM
I just noticed you have an '81. didn't realize it was that much older than my '96. What year did they switch from external pumps to internal pumps?
Old 08-22-2014, 05:33 PM
RL250's Avatar
Quote:
Fuel injected engines got internals. The bullnose crowd said Ford used both on the mid-80's trucks. A low pressure in tank and a booster pump after the selector.
Edit: the company that makes the EFI kit I am looking at advises against the external pump because of how the carb tanks are designed. They draw from the top, and inter a pumps push from the bottom of the tanks.
Old 08-23-2014, 02:49 AM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
I just dropped my efi tank today. If you need more pics or one of a certain angle let me know while I still have it pulled
Feedback Requested - 86 F-150 Fuel Probs Tommky 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-01-2015 08:35 AM
69 F100 Fuel Injection Freds69 1967 - 1972 F-100 & Larger F-Series Trucks 5 03-29-2015 12:47 PM
no power to fuel pumps mitchgordon96 1987 - 1996 F150 & Larger F-Series Trucks 2 12-02-2014 02:10 PM
EFI tank question RL250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-22-2014 10:54 PM
Fuel injection in 79 1979 300i6 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-28-2014 04:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
