Fuel filter
Fuel filter
I have an F250, 5.8L 2wd, auto...
I have 2 gas tanks. I have traced the lines to the tank switch then 2 lines from the tank switch to the fuel pump, then one line from the fuel pump to the carb. nowhere in the system do I see a fuel filter. The lines going from the tank switch mechanism to the hard lines leading to the fuel pump are not stock and have been replaced at some point.
I removed the carb screen inspected and found it old..but clean. The fuel pump is the mechanical type. So the only possibilities are: Filters in the tank or no filter beyond the carb screen. I have not dropped a tank.
any thoughts, am i missing something here? on the older mechanical systems were there filters in the tanks in a duel tank system?
triplepinned
11-17-2017 12:39 PM
tomwhatley
09-27-2014 08:21 AM
pit_of_pity
05-09-2011 06:56 PM
dfwrider
29
10-06-2009 02:05 AM
