Busted another set of sway bar links - Ford Truck Enthusiasts Forums
Old 08-21-2014, 11:27 PM
CPL_Guimonster CPL_Guimonster is offline
CPL_Guimonster is starting off with a positive reputation.
I have noticed a serious bump steer or a violent jerking action when hitting a bump in the road. just over a year ago i replaced ball joints,tie rods,sway bar links(2nd set since cutting off original).i used MOOG components. i was shocked to see the sway bar links loose once again. is there a certain way to tighten them or is there a better product available. Mostly stock 1999 'ploder with fire wires and scremin demon coil pack.(love it)
Old 08-22-2014, 07:41 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Did you inspect the link to determine if it's a clean break or rusted through?
When I replace the links in my 2000 Mountaineer, the standard aftermarket replacement was more like the old school link with the supports for the bushings, the tube, the long threaded rod and a couple of nuts. There was no provision to prevent over tightening. If I remember correctly there was an instruction sheet that basically said to tighten the nuts down until the bushings just start to deform. Doing so caused them to look like they were still loose so I went a bit beyond that.
The OEM links had rusted through but their design would prevent extreme over tightening, plug the service manual torque spec would further reduce the chance of over tightening. You could switch back to OEM links.
-Rod
Old 08-22-2014, 08:56 AM
Yea. The rubber bushing is worn to nothing. I can slide the link a good inch or so. The bolt is intact. The rubber bushings are worn out.
Old 08-22-2014, 01:31 PM
shorod's Avatar
Sounds like they might have been over-tightened. It's easy to do.
-Rod
Chasing a clunk and a squeak Strokerboy73 1999 - 2003 7.3L Power Stroke Diesel 13 03-11-2016 02:49 PM
Hellwig rear sway bar longer end links? 2002exPSD Excursion - King of SUVs 17 01-21-2016 09:47 PM
sway bar links anthonym92 1987 - 1996 F150 & Larger F-Series Trucks 11 04-05-2015 01:54 PM
Sway bar end links? 94MustangGT 1987 - 1996 F150 & Larger F-Series Trucks 7 11-06-2014 05:23 PM
Sway bar end links Billholthues Excursion - King of SUVs 6 09-04-2006 03:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
