Replaced Fuel pump--it won't start - Ford Truck Enthusiasts Forums
Old 08-21-2014, 06:55 PM
desertdogs desertdogs is offline
desertdogs is starting off with a positive reputation.
Angry Replaced Fuel pump--it won't start
97' 7.3 turbo.........a couple weeks ago I sprung a huge leak from my filter housing..it was shooting a stream of fuel 6' easily. I had only driven to the gas station and back and used up almost half a tank of fuel in less than 30 miles. I put in a new o'ring kit in the fuel bowl, new filter and checked for leaks every where. I went to start it and not even a cough. I was told it could possibly be the fuel pump had crapped out so I tore the thing down and replaced the pump with a brand new one. Every thing fit in nicely and got her back together and thought I had it licked. I even filled the fuel bowl hoping to prime it so it wouldn't have to work so hard. I went to start it and turned it over for about 20 seconds at a time and nothing. I did that about 8 times and still won't start. It's acting like she's not getting fuel, it was still running when I shut it down because of the leak but now it won't even fart. My batteries are almost new and turn it over at least 200-250 rpm. I keep thinking because of the massive leak it may have kicked the fuel pump reset on it but can't find that sucker either.
I need to get this thing on the road quick...also no reading on the scanner either........ I'm seriously losing it guys, I've actually been thinking of checking out my Israeli penetrator rounds on it.
Old 08-21-2014, 07:13 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is online now
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
My guess. You popped the fuel bowl heater fuse. 20 amp fuse. I think it's in the main box under the hood but not positive.
Old 08-21-2014, 07:50 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
make sure every connector is back on. i had a simmilar issue when i did mine. that was embarrasing. it sounds stupid but it happens.
Old 08-21-2014, 08:26 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Do yiu have a wait to start light ?
Old 08-21-2014, 09:20 PM
quesey's Avatar
quesey quesey is offline
quesey is gaining momentum as a positive member of FTE.
Then it may just still have some air in it if the fuses are all good
Old 08-21-2014, 09:23 PM
quesey's Avatar
I'm bad when it comes to starting 1 that's had fuel system open. I use the bad stuff and get it started and just keep it running with it until it picks up fuel an oil to the injectors. I'm not say do that because you could hurt it if done WRONG
Old 08-21-2014, 11:22 PM
Thanks for all the ideas....well I pulled the fuel filter housing back out, I found a minor leak. While I had it out I found a mass of burnt wires all fused together, I repaired all the wiring and in my haste to get it back together I forgot to hook up the return lines to the regulator.....jumped in, turned the key and she fired right up. I got out and there was fuel pretty much pouring all over the place. I shut it down again and hooked up the return lines and then it wouldn't start again. Do those lines have to be in a certain order....I can't tell if one was supposed to go to the top or bottom, if I crossed those I wouldn't think it would matter. Also I'm wondering if I don't have a clog somewhere between my regulator and tank on the return lines. Any idea's out there, I can build hotrods and Harleys but don't know squat about fuel injection. Any help would be greatly appreciated, this is the best Ford forum out there.
Old 08-22-2014, 07:36 AM
fordpride's Avatar
It doesn't matter where they go. But the should kinda fall in place
97 F 350 stopped running BollumRay 1994.5 - 1997 7.3L Power Stroke Diesel 10 09-02-2015 10:52 AM
97 F-350 Shut down while driving BollumRay 1997 - 2003 F150 1 08-30-2015 10:22 PM
Won't start after changing out fuel pump finerant 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-16-2015 01:17 PM
Big Fuel Injection problems, need help quick! desertdogs 1994.5 - 1997 7.3L Power Stroke Diesel 10 08-06-2014 06:12 PM
2000 F350 w 7.3 no fuel in bowl ranger9010 1999 to 2016 Super Duty 27 10-01-2013 04:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
