Need help on checking codes with my AE on transmission
What do you mean by "no overdrive"? is your OD not working, OD light blinking or something else?
Ok hooked up the AE. I got two codes that pertain to tranny. P0717 & P0715. Looks like I need to look at tts sensor. I was thinking there were two of these one in back and one up front? After further test driving it will go in forth but the slightest bit of throttle will put it back down in 3rd.I Let the man that built the tranny test drive it he is the one that discovered that it would go into 4th but any throttle and went to 3rd. He suggested the sensor. I pulled codes and got above codes. I think I am on the right trail. Also I do have a chip and was thinking this might be some of the issue.I have gear head tunes with 1.5 injectors. What do y'all think.
The turbine speed sensor (TSS) is on top of the trans near the front of the trans. There is an output shaft speed sensor (OSS) on top of the trans towards the rear of the trans. There is no code for this sensor, so I wouldn't touch it.
The code indicates that the electrical circuit is open. This could be either a bad TSS or a broken wire to the TSS.
Received 3,649 Likes
on
P0717 indicates the PCM isn't seeing a signal from the turbine speed sensor. P0715 indicates that the electrical circuit to the TSS is open. Why do you think it is the throttle sensor?
I checked connections to both tss and OSS sensors found no issues. Ohmed out sensors got 4.2 at both sensors. Pulled both sensors cleaned swapped sensors and reinstalled. Test drove same symptoms are still there. I cleared the codes before test drive they did not return after. No flashing light at shifter. Now what.
What test should I perform with AE to figure this out and what numbers am I looking for?
The shift solenoid values will tell you when the PCM is trying to change gears. I don't remember the exact arrangement. I think SS1=1 and SS2=0 is first gear. SS1=1 and SS2=1 is second gear, SS1=0 and SS2=1 is 3rd gear and both SS=0 might be OD. I am going from memory here so I am not all that certain. It will be obvious once you connect the AE and watch the readings....when one of the shift solenoid value changes, the PCM is requesting a gear change.
The TCC solenoid will tell you when the PCM is trying to lock the TC.
The slip reading will tell you if the PCM actually is locked.
Some '99 models won't have the TC slip choice on AE......if that is the case, then simply connect as a 2000 model year and it will then work fine.
Hope this helps.
BTW....swapping the TSS and OSS only works on non-PTO transmissions.
Thanks to all of you for the help. I will try the tests and report back. Should I put the tss and OSS sensors back to there original position? As far as I know mine does not have a pto. As for checking the wiring to the PCM not sure how to do that, I didn't perform any tests on the wiring harness except for a visual test right where they plug in.
Good question....that is the first thing I would have done based on Mark's post.
To the OP...
If you can't find any obvious damage to the wiring harness, then you can use AE to check the circuit but you will need some way to provide a specific voltage to the sensor connector. The Power Probe Hook is able to help in this case. If I suspect a wiring issue, I connect my AE and display the voltage reading of the suspected circuit. In this case, you would select the TSS sensor (Turbine Shaft Speed)....might also be called Input Shaft Speed on some scanners. Then unplug the connector from the sensor and set the Power Probe Hook to deliver 1.5 volts and clip it onto the appropriate terminal....(the one that runs to the PCM). I then look at AE to see if the value is correct. If AE shows 0 volts....then I likely have a wiring harness issue. If that reading looks good , then turn on the truck and measure the other wire....the reading there should match the VRS (Voltage Reference Signal), usually pretty close to 5.0 volts.
Hope this helps.
EDIT: I think the TSS and OSS are hall effect sensors so they wouldn't have the VREF signal. So using AE to measure the voltage signal may not work. If you have the PP Hook, you can still send a 1 or 2 volt signal from the connector and then follow that wire to the other end and measure to see if you have the same reading. That would work I suppose....
To the OP...
Hope this helps.
