Front receiver and parking.
Old 08-21-2014, 12:50 PM
pkthomas's Avatar
pkthomas
pkthomas is offline
Is it okay to go over the weight rating of a front hitch if you are only parking a trailer? I want to get one but they all seem max out at 500/5000 lbs. I knew some of this is axle and frame limited. I would not go over those limits on the road, cargo tray or bikes. But I also want to be able to park the camper easier..
Old 08-21-2014, 02:40 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,076 Likes on 978 Posts
What's the hitch weight on the RV? No sweat on legality as you aren't on a public hwy, but will it hurt the truck? Can't tell without knowing what weight it is.
Old 08-21-2014, 02:55 PM
pkthomas's Avatar
pkthomas
pkthomas is offline
Just under 1k lbs. Trailer weighs about 8k loaded.
Old 08-21-2014, 03:07 PM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
I don't understand why you can't back up like everyone else?
Old 08-21-2014, 04:23 PM
pkthomas's Avatar
pkthomas
pkthomas is offline
In most situations I probably would just back up. I just want to know if it is an option for marital harmony when needed.
Old 08-21-2014, 04:43 PM
senix's Avatar
senix
senix is online now
Say nothing more..
Old 08-22-2014, 10:14 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
For just this purpose I'd surely do it.
Old 08-22-2014, 01:52 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
When we had slide in campers I had a front hitch to put the boat in, it worked but it took some getting used to with the steering tires that close to the hitch
Denny
Old 09-15-2014, 08:45 AM
heymrdj's Avatar
heymrdj
heymrdj is offline
1K on the front puts alot of weight on the frame, and a lot of pressure on the power steering system. Is there 1K of room left on the front axle? I think the problem is the rear of the truck frame is designed for the massive hitch, and in comparison, there is actually very little metal on the front end.
In the redneck sense, I've also seen these setups raise the rear end of a truck, but that was with way too much weight on the front.
Old 09-15-2014, 09:11 AM
senix's Avatar
senix
senix is online now
Depends. Each truck is different. If you have the snow plow package then there can certainly be room for the additional weight.
Old 09-16-2014, 11:16 AM
Rovernut's Avatar
Rovernut
Rovernut is offline
Just for parking I wouldn't worry about it. I'm assuming you're not moving the trailer more than 20 or 30 feet, then unhooking.
Old 09-16-2014, 12:19 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
Agreed, the stresses on the frame from a bouncing load going down the interstate are much higher than a low speed parking situation. I would be comfortable going a long way over posted rating in this situation.
Old 09-17-2014, 06:07 PM
pkthomas's Avatar
pkthomas
pkthomas is offline
Thank you for the responses. One more question. Has anyone used a winch mount on one of these?
Old 09-17-2014, 06:21 PM
Rovernut's Avatar
Rovernut
Rovernut is offline
People do. IMO advisability of such a winch mount really depends on the type of potential use.
Old 09-17-2014, 06:23 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
I have without issue. Make sure the pull is flat. Theres alot more horizontal strength to these front hitches than vertical.
Quick Reply: Front receiver and parking.
