Bed Removal ideas - Ford Truck Enthusiasts Forums
Bed Removal ideas
Old 08-21-2014, 11:32 AM
dennisb56's Avatar
dennisb56 dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.dennisb56 is gaining momentum as a positive member of FTE.
Bed Removal ideas
Hi Folks,
I'm looking for ideas. I need to remove the entire bed from my 52 to work on the frame and also to work on the bed. I'm basically a one man operation so I thought about buying a engine lift from HF and use it to lift the bed off the frame, (once I remove the neccessary hardware), then make some kind of wood cart to sit the bed on to make repairs on it, paint it, etc then reverse the process to reinstall. Does this sound like a plan? Do you think it will work? Anybody do this already? Open to any and all ideas.
Old 08-21-2014, 11:40 AM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
It's really not very heavy at all. It's a 2-man job if you have decent strength. Four people can run with it. Do you have a neighbor who can help for a minute to lift it off and carry it over to your stand? I just wouldn't spend the money on an engine lift unless you need it anyway.
Old 08-21-2014, 11:44 AM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Engine hoist will work one end at a time but may not be easy to raise the whole bed at once without it swinging around. When I first started out as a teenager I would raise one side of a car body and slide a 2x10 plank under it so that the plank stuck out well past the frame on both sides. Then same on the other end. Put concrete blocks stacked up to hold up the planks, then one end of a time raised the body up a little more and added blocks until the body was high enough to roll the chassis out. I used a floor jack to do it, didnt have room for the hoist in the small garage I was working in. Reverse to lower it back down.
Old 08-21-2014, 12:44 PM
dennisb56's Avatar
Thanks guys. I hate bothering people I like to work on my own at my own pace, I guess that's why its taken 8 yrs and my truck is still not the way I want it.
Old 08-21-2014, 02:15 PM
Okiedokie's Avatar
Okiedokie Okiedokie is offline
Okiedokie is starting off with a positive reputation.
I recently used my engine hoist to remove the bed from my 53 when I did a Tbird IRS swap. It is not easy to remove it that way if you can't roll the truck put from under it. The bed swings a LOT more than I expected. I hollered at a neighbor who helped steady it while I removed it and re-installed it. Now if You can roll the truck out from under it you would probably be fine.
Old 08-21-2014, 02:16 PM
04Z06Vette 04Z06Vette is offline
04Z06Vette is starting off with a positive reputation.
i used an engine hoist with 4 cargo straps so i could adjust each corner independently. you can usually rent a hoist if you are near a bigger town
Old 08-21-2014, 02:53 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
That's what I did, I got a HB chain hoist, used a length of 2" galvanized fencepost to spread any weight across my garage rafters. Ive used it to lift the bed, engine, bend x members, remove the hood , etc., etc., and its helped me as I too work alone.
Old 08-21-2014, 03:07 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Comments on what has been said. Being able to adjust the length of the straps or chains to keep the bed level is very important. Lightweight cable and cable clamps is an alternative to chain and straps. To keep the bed from swinging around out of control, attach a long stick to the bed and the other end of the stick where you can control the swing of the bed. The bed is not hard to control, you just want to be in control.
Old 08-21-2014, 05:07 PM
dennisb56's Avatar
thanks for everyones input. My bed has a very old rotten 3/4" sheet of plywood as a bed floor, not sure how its coming out but it will and soon.
Appreciate all the ideas and pictures.
Old 08-21-2014, 08:43 PM
Tyler S's Avatar
Tyler S Tyler S is offline
Tyler S has a good reputation on FTE.Tyler S has a good reputation on FTE.Tyler S has a good reputation on FTE.
Have you considered rigging a pulley system from your garage rafters? One for each side or one for each end. Run a rope thru your stake pockets. It's pretty easy, you can keep things nice and steady and since a bed is pretty light (I'm guessing 80ish lbs) it's not too hard to do yourself. Just a thought. Good luck. T
Old 08-22-2014, 07:01 AM
fordf348's Avatar
fordf348 fordf348 is offline
fordf348 is starting off with a positive reputation.
Dennis, if you can get it loose from the frame I would be glad to give you a hand lifting it off
Ed
Old 08-22-2014, 08:21 AM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
I built a quick roll around cart to rest the bed on. I used the casters off a cheap H/F moving dolly. I assembled it with screws and bolts so that I could take it apart easily. Problem is.....its so handy that I have yet to take it back apart.
As far as lifting the bed, I've got a hoist mounted to a beam in the ceiling of my shop and I use adjustable tie down straps that I can loosen or tighten to balance the bed as I lift it. I have used my engine lift when I can't roll the truck out from under the bed. Having a tractor with a loader comes in handy too.
Old 08-22-2014, 09:29 AM
Boomer61's Avatar
Boomer61 Boomer61 is offline
Boomer61 is starting off with a positive reputation.
Ha! Now that 'rotten plywood' part has a familiar ring to it. Same issue I had. In my case, the PO hadn't bolted the body back to the rails, so I just grabbed it and flipped it off. Used the hydraulic lift on back of my Farmall tractor to lift and haul it out back for the time being.
Weight is less the issue as mentioned, it's more the awkwardness. The hoist idea makes the most sense if you want to do it alone. Even a come-along should work. Tie off one corner to prevent swinging, lift it off, move truck from beneath, set it down on blocks, sawhorses, whatever works for you.
Old 08-22-2014, 11:47 AM
KGP50's Avatar
KGP50 KGP50 is offline
KGP50 is starting off with a positive reputation.
Here's one more variation on the one-man bed lifting operation with an engine hoist. Sure makes that operation handy. The bed rests on the framework (built with 1-1/2" angle iron and square tube and caster wheels) of an assembly table that does double duty for bed assembly and general work when I top the frame with 3/4" plywood.
Old 08-22-2014, 12:10 PM
oldwi oldwi is offline
oldwi is starting off with a positive reputation.
Quote:
Here is my version of it. I made a simple frame to lift the bed off the truck with a cheap HF Chain Hoist. Once raised up I drive the truck out from underneath the bed and lower the bed down onto jack stands or saw horses to work on it. It worked well for me and allows me to remove the bed by myself.
Removing the 8' bed off my 79 F150 4x4 Old Brown Truck 1973 - 1979 F-100 & Larger F-Series Trucks 14 06-16-2015 12:07 PM
1967 F100 4x4 - Flatbed Conversion (Video) Mister_King 1967 - 1972 F-100 & Larger F-Series Trucks 20 03-20-2015 11:58 AM
Short, Long or Medium Bed Texasknowhow 1967 - 1972 F-100 & Larger F-Series Trucks 37 01-19-2015 10:29 AM
Bed removal rwrogers 1961 - 1966 F-100 & Larger F-Series Trucks 7 02-05-2014 09:56 PM
Bed Removal dennisb56 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-24-2013 02:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
