F500
F500
I'm wondering if this is a project I want to take on.
1956 FORD F-500
I'm wondering what is just like an F100 and what won't fit. And are these the widowmaker wheels and will later models wheels fit.
1956 FORD F-500
I do like the larger trucks and that appears to be a nice one. I would be all over it, at least to determine it is as solid as it appears. Cab, doors and engine will be the same as F100, not much else. Those should not be the widowmaker wheels. This is a big truck compared to the F100. If the engine is original, it is probably the 272, not that it makes much difference. Someone needs to check that out and save it.
Edit: I do believe that is a Ford script bed. Can't see much of it but what I see looks script.
Just popped up on CL this morning. Its in Jackson, TN about 75 miles up I40 from here. If it could be driven home I would be a little more on fire about it. Or if it was a COE. Or if it would come closer to fitting in my shop! Maybe I'll check into it this weekend. If it were a driver, it wouldn't last long around here.
Pinch off a brake line!!? I don't know about that one. I would have to drive it that way for at least 70 mile - I40 or US 70!
That one does look about as nice as they come, especially for mid-west/east trucks. A lot of work has been done. If one's looking for a bigger truck, and a 56 even, this appears to be the one to have. You'll kick yourself later if you pass it up over a fuel pump and wheel cylinder.
2.) Just missed a 1929 Model A Fordoor for $6000. Needed nothing.
3.) Missed a 55 Nomad driver for $7500 few years ago
4.) Kick myself a lot!
5.) NO -- still don't have a pile of money in the bank!!
