F500 - Page 2 - Ford Truck Enthusiasts Forums
F500
Old 08-21-2014, 01:39 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Quote:
Originally Posted by GB SISSON View Post
Pinching off a brake line is no big deal. You still have 3. (Statistics show most accidents occur within 3 miles from home, so the first 67 miles are easy ) And BTW it DOES look like a script bed to me.
Actually you still have 4 (both fronts and 2 tires on one side)
With no load I wouldn't be afraid to drive it on just the fronts.
I'm wondering if I could make some free time for a road trip this weekend. I could borrow my buddies motor cycle, drive it there, load the bike on the back and DRIVE that rig home!
There I go thinking again...... I have to stop it gets me into trouble
Old 08-21-2014, 02:04 PM
Fifty4F100's Avatar
Fifty4F100 Fifty4F100 is offline
Fifty4F100 is gaining momentum as a positive member of FTE.Fifty4F100 is gaining momentum as a positive member of FTE.
I'm thinking what would a 56 motorhome look like?
Old 08-21-2014, 02:13 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Put a brass or copper rivet in the rear line at the master. That blocks off both back
brakes. Than throw on a fuel pump and drive her home. Better than smashing a brake line to block it off.
Most of these ads saying it just needs a pump or a carb or dizzy cap
may be a way to cover up more serious problems with the engine.
If was me I would not give him a dime until the new pump was on and I was convinced it had no
other problems. But ya could gravity feed the engine from a jug and better know if
it just needs a pump or more.
Old 08-21-2014, 02:32 PM
Quote:
A "56 mobile home with a dash board from a "56 truck. Duh
Just kidding, But. Prolly pretty rotten I would think.
More pic's are needed for sure. I had a "56 Ford Courier with a build on
camper and the standard Courier that was nothing more than a panel.
Both cool and rare. But the Rust demon got them.
Old 08-21-2014, 02:42 PM
Fifty4F100's Avatar
Did a google search and looked at the pic page. Didn't produce much. But one funky looking 56 Caddilac Deville with a truck bed camper melded in.
Wonder what a truck camper looked like in 1956? Back to google!
Old 08-21-2014, 05:43 PM
Fifty4F100's Avatar
Who thinks the F500 rear wheel cylinder is the same as an F250 or F350?
Old 08-22-2014, 10:49 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
No proof right here, but in my experience they are quite a bit larger. Driven a lot of trucks with a 6 gallon outboard motor tank sitting up on a crate on the flatbed. They have a lot going for them. No rotten gas and rust from the truck's tank, instant priming with the squeeze ball, and even a gas gauge. I'm using my '58 f600 with one in one of the side compartments, but I have a working fuel pump. C'mon, it's Friday! That gives you the weekend to get this valuable piece of history home......Don't forget the camera. Many of us are counting on you,
Old 08-22-2014, 10:54 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
No one who knows better. F-250 and 350 cylinders are different from each other. F-500 and 600 use a totally different brake design that has two wheel cylinders on each side.
Old 08-22-2014, 01:14 PM
pweng1's Avatar
pweng1 pweng1 is offline
pweng1 has a good reputation on FTE.pweng1 has a good reputation on FTE.
Interchange
check the base number on wheel cyl. to compare casings and size. They used those casings/housings on later years that may be able to still buy but i doubt anything too recent.
Old 08-22-2014, 07:47 PM
Fifty4F100's Avatar
Finally got a few texts back from the seller. He found that Dennis Carpenter sells some wheel cylinders. He said he would drop the price $50 for the tow home. I was going to offer $2000 and try to hold out for at least $2500. And that's if there's no surprizes concerning sheet metal, floorboards, cab corners. But now I've found a Ranchero much more local for $1700. 351C or M. I think its a 73. Doesn't look bad.
Old 08-22-2014, 08:29 PM
abe's Avatar
abe abe is offline
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Buy them both!
Old 08-25-2014, 06:14 PM
Fifty4F100's Avatar
Quote:
Originally Posted by abe View Post
Buy them both!
Float me a loan! I'm good for it!!
Latest: he's telling me now there's a towing company in Jackson that will tow it here for $75 (can't get a tow across Memphis for that) and he'll drop the price $100. I was looking to offer $2000 and drive it off.
  #28
Old 09-03-2014, 09:42 PM
Fifty4F100's Avatar
Update:
1956 FORD F-500
He's down to $2200!
  #29
Old 09-04-2014, 01:23 AM
Looks and sounds like a heck of a great buy for someone
needing a truck like that. If true it needs very little to be
put to work. Damn nice barn find for sure. And sounds like
they have kept it up or just went through it for resale.
F500 front fenders vs F100 craftsmangary 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 09-15-2016 06:40 PM
Gas tank question CurtLarson 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 03-30-2016 10:25 PM
Quick question 54 F500 CurtLarson 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-03-2015 09:13 PM
Fender Well Headers for F500? Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 05-11-2015 04:49 PM
1956 F500 Brake Lines Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 12-20-2014 11:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
