TorqueGas LPG Injection - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 08-21-2014, 06:34 AM
Blue7.3's Avatar
Blue7.3 Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
Brian , that Gas mastor company looks very similar to the Torque gas .
GasMastor
No i haven't heard of them but have read their web page and for being in business for so long they must be okay and know what they are doing .
The application sound very much the same principle as what i have installed on my truck.
Old 08-25-2014, 05:39 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
This looks like a good investment for the big lap (around Australia), increased range, decreased coking of the engine. lots of benefits on the graphs shown.
What's the ballpark cost for an 7.3 installation?
Old 08-25-2014, 06:39 AM
Blue7.3's Avatar
The price for that system was about $2200 that was quite a few years ago, possibly a lot more now, but well worth it.
Old 08-25-2014, 12:39 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
My personal 2c - and don't take this personally Blue7.3!
I wouldn't fit LPG to a Diesel. I know there are a number of them getting around in Australia, but there are a few problems, chief of which that LPG/Propane will pre-combust on a diesel - and while some diesels will tolerate some "pinging", its ultimately going to shorten the life of the engine.
Old 08-25-2014, 04:50 PM
Blue7.3's Avatar
Okay Adrian , will take that into account , some more research i will do and report back.
How many trucks that you know of that have melted pistons or blown up due to LPG injection, as apposed to turbo failure on these trucks?
The LPG is not injected into the motor all the time only when the rev's are at 2200 and over, this is only used for extra torque when towing.
Thanks for the concern, i will lock into it
Old 08-25-2014, 05:51 PM
My experience is more with US trucks, that often used to use it back in the early 2000's as a "power adder" - it was a very popular addition... until a lot of people started melting pistons, and you don't see it much now-a-days there as a result.
http://www.ford-trucks.com/forums/10...s-propane.html
http://www.ford-trucks.com/forums/71...the-7-3-a.html
The main problem is, the auto ignition temp for propane and butane (the combo which makes Aus LPG) is 470 and 410 C respectively. Our diesels will compress the air till around 600-650 C to ignite the diesel, so it will pre-ignite the propane before the piston is near TDC. If you are only injecting very small amounts, the engine should be able to handle this with limited ill affects, but if you are doing that - any fuel savings you will see will probably be offset by the cost of the LPG + the system cost, and any power gains you get can often be obtained much cheaper and safer by adding more fuel (and air).
Old 08-25-2014, 08:13 PM
Aussie BrianB's Avatar
Aussie BrianB Aussie BrianB is online now
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
Quote:
Much food for thought Adrian, thanks once again for your high tech info.
Brians truck shop jgilrfr 1999 - 2003 7.3L Power Stroke Diesel 20 10-08-2015 08:19 AM
1999 f250 superduty no gas pressure??? Faster71 1999 to 2016 Super Duty 4 09-15-2015 12:05 AM
Bad Starter?? Twistedlarch Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 02-16-2015 06:21 PM
Bad starter?? Twistedlarch 1987 - 1996 F150 & Larger F-Series Trucks 2 01-27-2015 12:50 PM
oil leak Brian Skinner Aerostar 5 01-11-2015 05:07 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
