1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What is "Snow Plow Package" option?
Old 08-20-2014, 11:32 PM
RickBraden's Avatar
RickBraden
RickBraden is offline
Pick up 2015 F-350 6.7 PSD. On the window sticker it shows a Snow Plow Package that was only an $85.00 option. I was wondering what that could be? Thanks
Old 08-21-2014, 01:18 AM
DCP's Avatar
DCP
DCP is offline
Computer selected suspension and a heavy duty/extra heavy duty alternator according to the Ford website.
Old 08-21-2014, 05:20 AM
senix's Avatar
senix
senix is offline
Received 1,407 Likes on 1,003 Posts
maybe a different clutch fan strategy.
6K front springs.
And a warranty still intact if you use the plow and your front end wears early.
Old 08-21-2014, 08:00 AM
RickBraden's Avatar
RickBraden
Snow plow package
Thank you for the info guys. It will never see a plow. This last truck is for retirement 5th wheel only.
Old 08-21-2014, 09:00 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
I have the snow plow prep option on my '07 (6k front springs, fan clutch, alternator), I've never used a plow with this truck and it hasn't been detrimental. I wouldn't consider it a plus or a minus until you're well into the list of things you do and don't want on the sticker.
Old 08-21-2014, 01:49 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
in my opinion its an option that SHOULD be standard on all Super Duty trucks......
Old 08-21-2014, 01:53 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
I know in the older models it also included a larger transmission cooler, Im not sure if that still applies to the most current trucks.
Old 08-21-2014, 01:57 PM
SuperDutyScaler
also one of them "should be standard on a super duty" option
Old 08-21-2014, 01:59 PM
SuperDutyScaler
it sucks when you think O im buying this brand new F350 to tow and haul and plow snow then months later your told you didn't get the plow package so no heavy duty front springs no hd battery alternator and fan clutch. O i want to tow my camper of equipment trailer and now i need air bags or add-a-leafs because my truck didn't come with overload springs......... its just sad
Old 08-21-2014, 03:35 PM
onedcharette's Avatar
onedcharette
onedcharette is offline
snow plow pkg = no need for a leveling kit.
I purchased mine when I lived in NH. It does come with the stiffer front end and the heavy duty alternator. Never had a plow on it.
Old 08-21-2014, 07:48 PM
Ferguson65's Avatar
Ferguson65
Ferguson65 is offline
I think everybody else covered it. I ordered mine without it and the salesman looked at me like I was nuts. It's only $85, but the heavier front springs make the front taller and the dually already has too little rake. I wanted to avoid airbags, but the rear springs suck and I had to install them anyway. My truck will never, ever, see a plow.
Old 08-22-2014, 08:21 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
I prefer it because the Diesel engine is heavy and I think the stiffer springs prevent wollowing or bouncing on some of these rough roads. What ever spring choice you go with, aftermarket shocks are a must.
Old 08-22-2014, 09:27 PM
RickBraden's Avatar
RickBraden
Thank you. I didn't know that. What do the aftermarket shocks do for you? I don't have enough experience to know that. I have an '04 F-250 6.0 with only 44k miles. The truck seems to feel fine on the 4 original shocks. I did have to replace the original steering type shock that is horizontally mounted widthwise across the truck.
Old 08-23-2014, 06:17 AM
senix's Avatar
senix
senix is offline
I don't buy into getting the shocks unless you have a problem.
Old 08-23-2014, 06:59 PM
dualwheels66
To me the truck feels more controlled, more settled, especially on bumpy PA roads when you have better shocks. It's one of those things where you don't notice how bad factory shocks are until you replace them with a quality shock.
Quick Reply: What is "Snow Plow Package" option?
