Good news!...and bad news...mostly the ABS being a pain in the a** - Ford Truck Enthusiasts Forums
Old 08-21-2014, 12:29 AM
HKmnU97 HKmnU97 is offline
HKmnU97 is starting off with a positive reputation.
So I got my deal with the '97 F250 straightened out, the one with the rebuilt title from my earlier thread.
She passed all the major parts of the checklist, but will win no beauty contests.
Aaanyway, the title came from Alaska and in order to have her retitled here in Georgia she has to pass a systems checklist by the DMV. The p.o. had attempted the test but failed on ONE topic, that F****** ABS light.
Now I am not out of the realm of getting behind the gauges and wiring the ABS bulb into something else, say the e-brake warning bulb just to pass the systems check, but I want to know what is going on.
P.O. says these items have been replaced:
Rear diff. sensor
ABS control valve
Fuses are good, I checked them.
Wire connections seem to be good all the way down the frame rail to the sensor.
Also he says it wont give a code when he had it scanned.-now this could be due to improper equipment or operator error.
Honestly since there is only ONE speed sensor, and ONE control valve, and ONE fuse what else can go wrong? What else could be causing that light to come on and stay on? Could it be the ABS control module? How do I test the module? ....and (dumb question of the day) where is it?
Should I have it scanned at the Ford place?
BTW, it does the little automatic syst. check when you turn the key, when you fire it up the light usually goes out, BUT just as soon as you let off the brake to back up or pull forward, it comes on and refuses to go out.
Any help would be greatly appreciated! This last step and she is mine
Old 08-21-2014, 01:52 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Prob a odd question, (I have my reasons though) but does it go off if you put the turn signal on? Check all your lights and make sure they are in working order. Even third brake light. Does it have any LED bulbs?
Old 08-21-2014, 03:05 AM
DarkStarMedia DarkStarMedia is offline
DarkStarMedia is gaining momentum as a positive member of FTE.DarkStarMedia is gaining momentum as a positive member of FTE.
There is a two pronged plug just to the right of center, just under the dash. With the key on and the abs light on, it will put the abs computer in diag mode. This will flash out codes using the abs light.
The abs module is stand alone and not connected to the diag port at all iirc.
Richard
Edt... You short the terminals with a paperclip or some wire...
Old 08-21-2014, 07:42 AM
All the lights function, turn signals, headlights, low/hi beams, tail lights brake lights, etc.
No leds, no aftermarket lights except for some license plate bulbs which are incandescent.
What does it mean if the thing just stays on constantly? There is no flashing, it is just on all the freakin time when ever the truck is running.
Old 08-21-2014, 08:55 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Use the jumper mentioned above to pull the ABS codes and you can use the link below to decode them.
1996 Bronco/F-Series Workshop Manual
Go to section 06, then 06-09A, then click on "Symptom Chart" in the Diagnosis and Testing section. That has the troubleshooting steps and links to the pinpoint tests you will need to figure out what is going on.
If they have, indeed, replaced all that then the only things left are the wiring and the ABS controller itself. I would try swapping out the controller if you have access to one to try or can find one used for cheap.
Also, for what it's worth, if you unplug the ABS controller behind the glovebox, the light will go out and not work any more. Don't ask me how I know this, lol.
Old 08-21-2014, 11:25 AM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
This is going to be my suggestion as well....that or take out the bulb and move on...LOL
Old 08-21-2014, 12:25 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^ Would probably still fail the inspection, the same as if it were on. If it doesn't come on during the key-on bulb check, they'd fail it for that.
Old 08-21-2014, 02:00 PM
Quote:
I kinda wondered about that...
Old 08-21-2014, 03:02 PM
Wow, seriously? That blows...
Old 08-21-2014, 04:06 PM
Thanks for the responses guys. I went this afternoon and had it tested, they said the ABS control valve (directly under the drivers seat on the frame) was bad. This is a remanufactured part that the P.O. installed. Are they particularly bad about failing when remanufactured?
Also here is my sneaky back up plan:
Pop the gauge cluster out, cut the wire going to the ABS light bulb, and tie it into something like the brake light bulb or battery light that comes on when you turn the key but off when you start the truck.
That way, the ABS light will be drawing from the same power coming from one of the systems that IS functioning properly. Since they DO check to see if it comes on at all.
Old 08-21-2014, 05:00 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Or you could fix it the correct way so your brakes work the correct way. That way your rears won't lock up on a panic and leave you doing 360's in the road.
Just my .02
Old 08-21-2014, 05:14 PM
Yes ultimately I would like to have it fixed right BUT I did the moron test last night and the ABS system DOES work, trust me
btw moron test = get out alone on a 2 lane hwy get up to about 45mph and try to stop the beast on a dime. you can slightly feel the ABS system working.
So I just went out to the parking lot and examined the sensor on the side of the brake pedal very closely (stopswitch or something like that). Unplugged it, and shorted the 2 prong recpt. wire going to it. Turned the key for dash lights, ABS light came on, then went off. Fired the truck up, that ******* stayed off. Stomped on the brakes a couple times, STILL off. Scootched it back and forth in the parking lot some. still off.
Havent hooked it back up, still has the jumper wire stuck in it.
I am assuming the short initiated some sort of reset? perhaps a step the p.o. overlooked when he replaced the rear speed sensor?
Hoping this has fixed it, will update soon, thanks everyone!
Old 08-21-2014, 05:17 PM
Quote:
_Probably_ is the key word. Can't say for sure; inspections vary from state to state. But logic (which, of course, doesn't always apply with gov'ts...) would dictate that if an inspection would fail on a particular warning light being on, it would also fail on that light NOT lighting during the bulb check.
The "battery" light is actually a charging system failure warning light. And the light bulb itself is actually part of the charging circuit. Tying another bulb into the circuit might play cattywumpus with your charging system.
If you tie it into the red BRAKE (!) failure warning light, when the inspector applies the parking brake, the ABS light will go on with the red BRAKE (!) light, and s/he'll no doubt suspect something.
Moreover, there are no "wires" going to the bulbs. The bulbs go into a circuit board. You'd have to cut the corresponding wires on the connector(s) into the board.
As said, finding and fixing the reason the light is on is the most expedient approach.
Old 08-21-2014, 05:24 PM
That "sensor" is the brake pedal switch. Meaning, while it's jumpered, your brake lights are on. Driving around with your brake lights on all the time is as dangerous as driving around with no brake lights.
Old 08-21-2014, 05:26 PM
Yeah I just found that out with the brake lights.
So why does the ABS light stay off when the brakes are "depressed"?
REALLY NEED HELP!!! (ABS Control Module) 7.5GasHog 1968-2013 Full Size Vans 22 08-30-2016 01:18 PM
Electrical Glitches / Electrical / Electronic Diagnostics / Fixes Thread. gearloose1 6.0L Power Stroke Diesel 39 08-12-2016 06:22 PM
ABS light ReBilld 1994.5 - 1997 7.3L Power Stroke Diesel 38 07-16-2015 07:16 PM
ABS speed sensor mounted on the rear differential part number lalamar Ranger & B-Series 5 08-15-2012 03:00 PM
Speedometer/odometer P0500 98 Ranger bnclements Ranger & B-Series 2 05-24-2012 07:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
