97 f250 major gas mileage help - Ford Truck Enthusiasts Forums
Old 08-20-2014, 11:59 PM
peterb1213 peterb1213 is offline
peterb1213 is starting off with a positive reputation.
Hey I'm 16 and I just bought my first truck. 97 f250 xlt. With a 7.5l 460 engine and just hit the 50k Mark on the odometer. I commute 40 miles day minimum for work and I get horrible gas millage, not average horrible for a 7.5 like 8mpg. I'm getting about 4_5mpg. I've tried everything. New cap and rotor, new air filter(old one was trashed), and lowered the idle. The air filter definitely gave me more power but didn't really help my mpg. I really need help with this because if I don't up my mileage I'm either gonna sell the truck or find a new job ( I like the truck more than the job )
Old 08-21-2014, 06:25 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Welcome to FTE peterb1213. I moved your thread to the correct forum.
Old 08-21-2014, 07:24 AM
Old Trusty's Avatar
Old Trusty Old Trusty is offline
Old Trusty is starting off with a positive reputation.
MPG's or GPM's
The biggest way to increase your milage in the 460 is to SLOW DOWN! I love mine but I drive it like a 85 yr old geriatric. I shift a 2k rpm and accelerate from 0-60 in 9 miles I get 14 highway and about 10 in town. I was going to create a thread about exhaust and getting my 460 to sound real throaty and mean until I got a little road rage and stomped on the right pedal low and behold my big a$$ motor sounds awesome! Around 3k rpm but that eats through a tank of gas in no time.
I remember being 16yrs old, I know how I'd drive my truck if I was 16 again, my answer to you would be to find a Craigslist 4 banger cheap (by cheap I mean almost embarrassing to drive cheap) and keep the '97 clean and awesome!
Sounds like a sweet rig would love to see it !!!
Old 08-21-2014, 09:01 AM
Of coarse I've put the pedal down a few times but realized I can see my gas gauge go down even quicker. I accelerate fairly slow and always use cruise once I get up to speed.
Old 08-21-2014, 09:03 AM
O and thanks it is pretty nice I'll throw up some pictures later
Old 08-21-2014, 09:32 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
How did you "lowered the idle"?
How old are the plugs and wires?
Have you checked for codes? You may not have a Check Engine Light, but there can still be stored codes and issues that would trigger a code in the Key On Engine Off tests.
Old 08-21-2014, 09:36 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
What is the full story here.
Does the truck have a lift and big tires?
What axle gearing does it have?
Is your commute mostly highway or stop and go traffic?
Are there any codes present?
Does it get the same milage on both tanks?
Old 08-21-2014, 09:37 AM
Idle screw,
Plugs I have no idea but wires are as old as the truck I believe
I hooked it up to a code reader and read clean two different times
Old 08-21-2014, 09:39 AM
Not lifted (thought about it until I saw tv's mps)
Not sure about the gearing
All highway
No codes
And have only been using one tank I use the other as a backup
Old 08-21-2014, 09:46 AM
Conanski's Avatar
Check the axle code on the drivers door pillar and post it up.
Does the truck have a 4sp OD trans or a 3sp?
You should alternate back and forth between tanks to keep them from gumming up. There is a common fuel transfer problem with these trucks too where gas is pumped into the other tank as you drive and if that tank is full it gets pushed up the filler tube and dumped on the ground. To check for this run a tank down close to empty and take note of the fuel level, then switch to the other tank and drive on it for maybe half a tank and then switch back to see if the level in the first tank has changed. It shouldn't of course, and you need to check this for both tanks because it can happen to both tanks. The fix is to replace the FDM in the tank that is receiving fuel.
Old 08-21-2014, 09:55 AM
It is a 4speed and Ill check the code
I'll try that but I think I would have noticed if it was dumping fuel out
Old 08-21-2014, 10:07 AM
rla2005's Avatar
Idle screw,
Put the screw back where you found it. It's only function is to keep the throttle butterflies from closing too far. They should stop just before fully closing.
Never under estimate the contributing factor of aged ignition components. Get those wires and plugs replaced.
If someone else has jacked with that idle stop screw that tells me there is another root cause of the problem. Probably a vacuum leak which can also cause poor fuel mileage.
Old 08-21-2014, 10:20 AM
Next pay day I'll do that, I was thinking about replacing the vacuum wires anyway, pretty old.
Old 08-21-2014, 11:13 AM
rla2005's Avatar
excellent plan
Old 08-21-2014, 11:34 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
It only dumps out when the tank becomes full. My truck has the same problem, blown check valve in the rear FDM. When I'm running on the front tank the fuel level drops quick, and if I didn't know any better I'd think she was getting worse mileage than my old 460 truck. In reality I know that most of the fuel just ended up in the rear tank which I don't let fill up completely, so it never ends up on the ground.
2004 F250 SD performance issues Oregon04SD 1999 to 2016 Super Duty 9 10-01-2015 07:30 PM
2006 E350 box van Poor fuel economy Troy Collier 1968-2013 Full Size Vans 13 01-21-2014 08:08 AM
F250 Superduty 6Ldiesel bad gas mileage flowerpower 6.0L Power Stroke Diesel 8 10-28-2009 05:31 PM
'89 F250. HORRIBLE gas mileage BRay09 1987 - 1996 F150 & Larger F-Series Trucks 36 11-08-2008 03:05 AM
6.0 Liter Fuel Economy shamblin123 6.0L Power Stroke Diesel 54 01-16-2007 05:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
