1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 6.0 stalls while driving
Old 08-27-2014, 02:13 PM
Pch77's Avatar
Pch77
Pch77 is offline
Ok, here is my problem
My truck will drive for about a mile, the stalls out. It won't start for about 45 min, and then she will stall again once I drive. No codes at all.
This is what has been replaced,
Fuel pump
Fuel filters
Fuel regulator spring
Icp
Ipr
Oil cooler
Egr
Egr valve
Hpop
Ficm
And she still stalls out. No codes. Mechanic at a loss. Any ideas would sure help.
Old 08-27-2014, 03:19 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
What happens to ICPV and IPR% when it stalls? Does it restart quickly after it sits for the 45 minutes, or does it crank over for a long time?
Verify low-pressure oil pressure at the oil filter base, or just pull the oil filter and cap and see if the housing fills up when you crank it.
Old 08-27-2014, 03:22 PM
Pch77's Avatar
Pch77
Pch77 is offline
Ipr stays in the good range. Ipc loses presure, well under 500. But then we unplug it. And it still won't start
Old 08-27-2014, 03:41 PM
Pch77's Avatar
Pch77
Pch77 is offline
It does take awhile to crank it, before it starts. But once it does it will idle all day long. We will try you suggestion on the oil filter. Thanks I'll let you know what we find out
Burt Watkins
10-15-2018 12:13 PM
jason poeppel
03-23-2017 01:23 PM
Pitchinfool
10-28-2011 10:53 AM
Scooter7227
09-17-2011 11:34 PM
plowin4u
03-17-2011 08:30 PM
Quick Reply: F250 6.0 stalls while driving
