Looking at buying a 2006 6.0L
Hi everyone,
Came here for some assistance. I'm looking at buying a 2005 (oops on the title) F350 with 250k KMs or about 150k miles on it. I've done a fair bit of research as far as the standard 6.0l issues and tried to book an appointment with a diesel mechanic for a pre-purchase inspection but that isn't going to happen. The truck is a 7 hour drive away from me and most mechanics aren't open on weekends. As far as the general checking the brakes, suspension, body, interior i'm good at looking over that stuff. As for the engine and transmission, are there checks i can do when looking at it/test driving. I have posted the listed upgrades and repairs that he has told me and will check the coolant and watch the gauges as per the posts i've read about what the readings should be. What else can i do to avoid buying a boat anchor?
copy and pasted:
Bulletproofed with ARP head studs, EGR delete, HPOP, AmsOil bypass system
Custom tuned SCT programmer, edge insight gauges
MBRP turbo back dual exhaust with drop pipe
AIrraid fibreglass ram air hood with AIrraid cold air intake, AFE intake manifold
ICON 4.5 inch lift. New 35" tires on 20" rims
RECON projector headlights, mirror lights, clearance light, HID fog lights
Aluminum headache rack and dry box. Also have a matching power tonneau cover with power locks etc.
2 way pager alarm and remote start
Pioneer DVD with navigation, backup camera, phone, iPod hookup. 10" sub
Heated leather seats, sunroof, power rear slider
thanks for the help!
copy and pasted:
What's the price on it? Otherwise it sounds like everything is done that's needed other than a few updated parts that could go in, but if it ain't broke don't worry about it yet.
Bringing a scangauge II with you to check for a plugged oil cooler could help, make sure it doesn't overheat and make sure there's no signs of puking because believe it or not ARP studs isn't a fix all/end all head gasket saver
Thanks for the quick reply!
You'll for sure see black smoke. Sounds like a good deal to me, i payed 11,900 canadian for mine and got significantly less in the upgrades.
If you can't track down a scangauge the only thing you'll be blind to is the oil cooler condition and FICM condition, which may or may not be a big deal to you.
Also make sure the truck is stone cold when you start it and make sure everything sounds okay and it doesn't stutter idling for a few moments (FICM/Inj. Issues)
The AmsOil bypass kit isn't bypassing the oil cooler if that's what your thinking, it's just allowing some oil to bypass the cooler to go through a 5 micron filter to clean your oil up a bit. Not even an issue to begin with if you do regular oil changes.
Basically look it over your best, can probably tell more about the trucks condition by the way the guy acts more than anything.
Ask questions and try to catch lies, it's fun
muddinbronco87
02-06-2016 11:17 PM
RideRed05
05-12-2006 09:48 AM
