Can all of our computer controlled distrubutors be upgraded with aftermarket controller?
Has anyone heard of this being done?
As I researched it, our computer controlled carbs control the ignition advance through the EEC-IV system. Our distrubutors send a signal to the EEC-IV system, that EEC-IV system reads various other sensors, and sends a signal back to our distributor.
Has anyone tried to actually work the existing distributor factory installed on our trucks?
I have not found anything for the EEC4 TFI ignition system so far and I been looking for some time too.
There is a aftermarket spark controller that is used for the Ford EDIS system.
Here's that link for the EDIS.... http://www.autosportlabs.net/Megajolt_Lite_Jr.
It may be possable to modify the software to operate a TFI system or design something up along these lines.
What Patrick and I are looking for is to use the TFI ignition system and carb without a ECU controlling the timing and carb(replace feedback carb to non feedback carb). Without a ECU the TFI is locked at base timing. I ran my 84 F250 that way till I found a good ECU at a reasonable price. Also the feedback carb gave me fits so I finaly went to EFI years ago. Now I am going back to the old Dura Spark 2 and Oppy DP intake and carb.
I did find this tonight.....
Better Dirt Cheap Electronic Ignition
Programmable Digital Ignition
Yes exactly. I found those links also. I plan to make one and report back results. I even did basic math timing calculations for how fast the signal would have to be..
My thoughts were a purely distributor based system that can produce it's own "SPOUT" after around 1500 rpms.. The module could be really cheap if mass produced, and all it would really need is +keyed ignition 12v , PIP (out to ecu), and intercept "SPOUT" . I am not even sure that the EECIV could pickup on such a disabled "SPOUT"
I'll save my criticism of MSD because it is well known.
The GM module controls dwell so you don't need a ballast resistor in the coil feed and can use your old Ecoil.
I don't know of ANY aftermarket performance EEC-IV computers..
Who in their right mind would use a feedback carb and TFI distributor in that application?
I'm not aware of your criticism/issues with MSD (I've been reading all the posts here for a while now and don't recall seeing anything).
I'm interested in what issues you've had because I run the MSD 6AL with an MSD Pro-Billet Street distributor and Start/Retard box. If there are known issues with these parts I'd like to know before I have an issue. So far everything is working fine.
Could you link me to one of your posts of just send me a quick PM if your issues are related to the parts I am using. Thanks
on
The Tfi-IV distributor is basicly just a hall effect sensor, the ECM and the ignition module are the brains of the operation. The older TFI modules handle dwell in the module.
This is the only thing I have ever run across that does what you are thinking: http://www.gofastforless.com/ignition/digital.htm
That is complely build and program it yourself though.
You may be able to do it with Megaspark as well(project was circa 02-03, and uses a megasquirt controller) but due to Ford using one window larger than the rest to tell the ECU cylinder position you will always end up with different timing on #1 than the rest.
You will also have to design and program your own timing curve and will not have a provision for vacuum advance.
This is why a Duraspark or HEI conversion is the common thing to do, mechanical and vacuum advance are tuneable and much more user friendly.
As for msd stuff I have run my 460 on a Digital 6 plus with a DS2 dizzy since 07 and have never had an issue.
I have seen a few of my friends have issues with 6a boxes though.
I run the DS2 dizzy as while it is a bit harder to recurve than a MSD unit, I prefer the bigger cap diameter and MSD uses a duraspark pickup and reluctor ring anyhow.
Check out this MegaSquirt link.
TFI Ignition Control
Another useful link.
http://www.myo-p.com/Ford-EEC/EEC%20..._or_black.html
And one more. I believe MegaSpark was the original MegaSquirt project. Looks kind of dated today.
http://home.comcast.net/~tjhafner/MegaSpark.html
Ya know you can just use one of there Cap-A-Dapts on there MSD dizzy, it's basically the stock DSII bottom cap adapter.
