Tires/Rims 77 - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Tires/Rims 77
Old 08-20-2014, 05:16 PM
acc2828 acc2828 is offline
acc2828 is starting off with a positive reputation.
Tires/Rims 77
I am going to up grade the tires that came with my 77 4x4. It came with 16.5'S. What do I need to know about bolt patern and size differences. I have done quite a bit to the engine. It is now running with396 HP about and 425 ft lb of torque. So Size doesn't matter. ( sorry NPI ), except for milage and speedometer reading. Sorry also 350 gears. I just want what would be comperable in todays numbers as to what was here in 77.
Old 08-21-2014, 01:56 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Well your profile says 77 F150, so if you have 16.5 rims that sounds odd to me. I always thought 16.5's were for F250's only?? And 15's were more common on a 1/2 ton.
I really doubt you can find any 16.5 tires that are cheap, other than 36", 37" military takeoffs.
Anyway a F150 1/2 ton is a 5 lug rim and the rim is described as a 5 on 5 1/2" and you can run 15's. But getting a rim that is for 16" tires should give you alot wider of options to buy tire wise.
There are tons of wheel and tire options out there, the options are almost overwhelming.
Try this to have fun, pic 73 F100 reg cab SB 2wd (only option to get a truck) and go from there.
Big O Tires - Wheel Visualizer
Old 08-21-2014, 10:14 PM
Tires and rims
thanks for the info. I was told a set of 33s would work but on 16,s. When I put the new rear axle bearing on they were .0015 to small and had to go with ? muncie bearings that would fit. I am not sure know as it has been a 2 year frame off and I foolishly did not write all that has been done up to this point. I am now just finally back to rebuild. Thanks Again
Old 08-22-2014, 12:12 AM
77&79F250's Avatar
Used OEM parts guy
As far as a set up that will work with a stock F150 4x4 truck, yes 33's should bolt on without a lift kit.
I would get the rest of the truck all back together and just use some shop rollers that way its still low enough to easily work on. And then go rim and tire shopping. Did you use that tire visualizer?
Old 08-22-2014, 06:22 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
is it a 5 lug axle or an 8 lug axle?
Old 08-23-2014, 02:54 AM
77&79F250's Avatar
Used OEM parts guy
The red truck in his gallery is a regular cab F150 and has 5 lugs and stock rims.
You ever hear or see 16.5 rims for a 5 lug, I haven't till now.
Old 08-23-2014, 07:22 AM
i ain't rite
yes, there are 5 lug 16.5 rims. that is why i asked.
they are hard to find, but they are out there.
i have also seen 8 lug 15 inch rims.
Old 08-23-2014, 07:34 AM
77&79F250's Avatar
Used OEM parts guy
I have seen some aftermarket 5 lug 16.5 white spokes from Summit, but never see stock steel ones.
And yes I have to seen 8 lug (8 on 6 1/2) x 15 rims before, I would have to guess that are off set enough to fit the duel piston front end.
I have a set of 8 hole 15" alum slotted mags...just setting the the shed, that are like 7 and 8.5 wide.
Old 08-25-2014, 08:02 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
I've got a soft spot for slots….
Old 08-26-2014, 06:40 AM
77&79F250's Avatar
Used OEM parts guy
Pm sent LeoJr.
Old 09-02-2014, 08:27 PM
Thanks guys. I am just reporting what was on the truck when I bought it. This was originally a arizona truck. It has 350s front and rear gears and the front I want to say is a 50 and the rear is a 60. What I found strange like i've said before is that the rear axle itself was like .0025's larger than the standard axle so i rear axle bearings for a muncie axle. ????? But I will probably go with the 33's But unsure of the wheels. If it weren't a 4x4 I would deffinetly go with some moonies I am partial to that mirror look.
Thanks Againn
Another tire size question?? tsuess 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-22-2015 05:25 PM
The saga of the boy's Franken-Truck 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-19-2015 08:56 AM
77 f250 ranger help my-ford 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-20-2014 04:43 AM
77 f250 sc stock tire size 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-13-2014 09:03 AM
77 f250 shackle bushing 77f-250HB 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-12-2013 07:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
