Problems with my power stroke - Ford Truck Enthusiasts Forums
Old 08-20-2014, 03:15 PM
2wd460 2wd460 is offline
2wd460 is starting off with a positive reputation.
Alright guys, I need some help. I have a 95 4x4 7.3 power stroke that this morning after driving it the day before would not start. It turned over but would not start. I also noticed while trying to start it from the down pipe on the turbo it was smoking. Don't know where to start looking or what to start replacing. Any advice, help or pointers would be appreciated.
Old 08-20-2014, 04:40 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Welcome to FTE! The best dern place on the internetzzz.
Does the Tachometer move while cranking? It should show around 500rpm if I recall correctly.
Old 08-20-2014, 04:52 PM
I haven't checked the tachometer to be honest. It's a healthy crank though.
Old 08-20-2014, 05:51 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
On the 95 the tach should move some while cranking, check that. Do you have a wait to start light?
mojoman mojoman is offline
mojoman is starting off with a positive reputation.
look at the tach while cranking...if it doesn't show 250-300 rpm I would suspect the CPS....hth
mojo
Old 08-20-2014, 05:57 PM
Quote:
Yeah I do have a wait to start light
Old 08-20-2014, 06:00 PM
Quote:
mojo
CPS....hmmmm ok well I'm gonna crank it and see what the tack reads. If it does move then I should be focusing on what besides the CPS...the PCM??
Old 08-20-2014, 06:04 PM
Power but no start Shooter19d General Diesel Discussion 3 08-19-2015 11:25 PM
95 to 02 power stroke differences? Moonpie6899 1994.5 - 1997 7.3L Power Stroke Diesel 6 01-19-2015 05:29 PM
Truck surges on start up welder41 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-10-2014 09:06 PM
starts then shuts down kxryder 1994.5 - 1997 7.3L Power Stroke Diesel 22 08-11-2011 11:01 AM
air box lid stubnessa 6.0L Power Stroke Diesel 11 06-03-2010 04:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
