1988 f-250 trouble getting into 4x4
Old 08-20-2014, 02:59 PM
codeman2443's Avatar
codeman2443
codeman2443 is offline
so I go to put my truck into 4x4 and I lock the hubs and when I pull the lever into 4H it doesn't set into place. I can drive for about 20 feet then it pops out of 4H. help please? its an automatic
Old 08-20-2014, 03:23 PM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
I would suspect the shift fork in the tcase has broken/worn sliders. I've only dealt with BW13-56 cases, and I'm not certain which case came in that truck. Someone else will chime in with more concrete diagnostics.
Edit: I'd also look at the shift linkage outside the case, between the lever and the case. Make sure it's tight. If its loose, see if you can manually shift the case into 4x4 at the case (not using in cab lever) and see if it stays in 4x4.
Old 08-20-2014, 08:01 PM
BruteFord's Avatar
BruteFord
BruteFord is offline
Tough one, I'd start with the lever mechanism itself, there is a shift gate mechanism on the outside. Make sure it's working, adjusted, the lever isn't being hit by the body, etc.
If it looks ok, shift it into 4H then remove the lever mechanism. Then try and move the shift rod by hand, does it move easy, does it fall into a detent position that it wasn't in, etc. Then drive it to see if it stays in 4H with the lever removed.
Old 08-20-2014, 09:00 PM
codeman2443
I got under there and messed with the linkage and levers and now I can get it into 4H by pulling back and shaking it from side to side a little bit. I will check some other stuff that takes more work to get to this weekend when I have time. thanks guys for the help
Razkid
01-22-2017 11:18 AM
SasquatchF-250
04-25-2014 10:47 AM
BFTUFF
1997 - 2003 F150
08-04-2011 12:16 AM
tbenks
01-06-2010 03:05 PM
cwt7691
09-19-2007 06:20 AM
Quick Reply: 1988 f-250 trouble getting into 4x4
