Order of mods - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Order of mods
Old 08-20-2014, 07:06 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Order of mods
There hasn't been an order of mods thread, and I've been asked a question. So I'll have a crack - feel free to chime in, disagree & say why.
Stage 1 - bolts ons with minimum F250 knowledge/experience:
1.1) Gauges - EGT, boost, trans temp - Scangauge or Edge can also be an option with additional sensors where required;
1.2) AIH delete;
1.3) Intake - AFe, 6637 with cover, AIS (Ford H/D);
1.4) IC boots and plenum inserts (or billet plenums);
1.5) Hutch mod (fuel pickup);
1.6) Harpoon mod if you've got the standard tank (allows easier fill to the top);
1.7) Steering stabiliser (single);
1.8) Fuel bowl military spec O-rings.
Stage 2 - requires turbo off - so a bit more involved:
2.1) IH bellowed uppie$;
2.2) Gen 2 WW (compressor wheel);
2.3) EBPV delete (mod existing or buy delete-pedestal);
2.4) Hi flow turbo outlet (easy add while turbo off & apart)
2.4) HPx (a snack with the turbo off);
2.5) OCR.
Stage 3 -
3.1) 4" exhaust, either 3.5 or 4" down pipe, (don't go muffler delete);
3.2) Trans valve body;
3.3) chip, DP F6 or Hydra;
3.4) FRx
Stage 4 -
4.1) Levelling kit - extra leaves for the front suspension;
4.2) higher rear blocks;
4.3) rims & tyres.
Stage 5 -
5.1) etc, etc, etc
Old 08-20-2014, 11:01 PM
Blue7.3's Avatar
Blue7.3 Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
Maybe put in there chassis mounted trans oil filter , pre and post fuel filters, also HPOP lines and fittings .
Here is a link to HP lines complete with HPx line.
COMPLETE REPLACEMENT HPOP AND HPX LINE KIT
Old 12-26-2015, 04:39 PM
rockman1 rockman1 is offline
rockman1 is starting off with a positive reputation.
many thanks to those that had added this list up
what about for us newby's to the f-truck thing , the bits that are mods , what if you had a link to what is done in the mod or if its a delete , what part got deleted and how ?.
Having this list of mods is awesome as it saves alot of people alot of heartache trying to get stuff sorted properly
cheers
Old 12-27-2015, 08:56 PM
Blue7.3's Avatar
Tell us what you intend on using the truck for and we can guide you from there.
Example , daily driver, race truck , show truck, or tow truck?
The mods can all depend on which way you use your truck, so you don't spend money you don't need too.
Old 12-27-2015, 10:58 PM
The f truck will be used primarily for work , towing a tandem trailer , defiantly not a show pony .
Every now and then it will be towing a sxs .
I still want something that goes well with out having reliability issue's as it is my work vehicle .
Regarding the mods , i would rather over-do the mods required for a quick but reliable ride .
The money spent on mods will be a tax write off .
Cheers
Old 12-28-2015, 01:15 AM
Blue7.3's Avatar
I'm assuming you have an auto, soooo I'd fit a larger trans cooler like this one , Ford 6.0L Powerstroke OEM Transmission Cooler , then gauges , trans temp, egt, boost and fuel pressure and or a ScanGauge 11 that plugs into your OBD11 port.
You'll be able to get a larger cooler here in AUS some where, for half the price.
Then intake , 4'' TB exhaust with a good straight through muffler, and a good chip not a tuner like the SC 1705 .
I like the DP-Tuner (Chip) or the hydra with a couple of tow tunes and a couple of daily drive tunes and maybe hi idle .
If you have any surge problems when towing heavy a WW2 of RR billet wheel will solve this for you.
Always carry spare sensors like CPS, ICP, IPR a fuel pump and a serpentine belt, fuel filter, in the truck just in case.
lots of mods but still not where i want to be breedo99 1994.5 - 1997 7.3L Power Stroke Diesel 41 03-13-2017 02:19 PM
Questions about my mods and upgrades Pigpen1 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-14-2016 08:29 AM
Common Mods SSSimon Australia Chapter 15 10-21-2013 06:48 AM
SD HPOP on 95 7.3L - does timing cover need mod? dhcarder 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-10-2013 01:16 AM
Stage 1, 2, 3 ??? fnx4wheeler Appearance & Dress-Up 1 10-08-2007 06:35 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
