Buying a '96 F150 - What to look for?
yo,
Besides the usual visual, driveability and leak checks, look for:
- oil pan rust -
radiator plastic side seam leaks esp. during engine cool-down period/overnight
auto tranny and transfer case operation - electric push button motor/connector is a prob. area
auto hub operation (get it in sand or mud and try the 4x4 system)
rust in inner rear fender lips and bottom of tailgate (our's was rusting due to beach sand wearing the paint)
radius arm bushing deterioration
cracked exhaust manifold/y etc.
- oil pan rust -
Originally posted by steve83
The tops of the rear wheelwells are steel, and they catch stuff & hold it at the seams. To clean it, pull the plastic wheelwells and blast everything out from on top. When it's dry, cover it with undercoating. That's what I did to the bottoms of my doors & tailgate (inside).
I do think that under coating would help in this situation, BUT I have heard of people clogging up drainage holes and causing water and other crud to stick and cause rust, which would be worse, in my opinion that never washing it because it is trapped.
Steve, would it be worth while to do on older vehicles? Like in my case, I've got very minor rust, would under coating help to stop more rust from happening?
Would drilling more holes on that side of the fender well help for salt and corrosion to drain quicker.
Originally posted by Pastmaster
...very minor rust, would under coating help to stop more rust from happening?
It's still a good thing to do - the insides of my doors & tailgate are heavily coated.
cougar694u
1997-2006 Expedition & Navigator
02-03-2011 10:25 PM
chuck864x4
06-22-2010 07:00 PM
