96' F350 Crew cab 4 x 4 XLT - Ford Truck Enthusiasts Forums
Old 08-19-2014, 09:20 PM
cityjack cityjack is offline
cityjack is starting off with a positive reputation.
Evening all,
I have a stock lift crew cab 4 x 4. I want to put lift leaf springs front back. I currently have 33's on it now. I wan to go with 37's probably. Where is a good place to purchase good quality leaf springs front and back? Do I need to use different lift heights for a typeof leveling kit? Not sure there.
Thanks
Sid
Old 08-19-2014, 09:25 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I recommend NOT going with your typical "lift springs"
Have a look here
My 97 CC 4wd Build - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old 08-19-2014, 09:39 PM
Old Trusty's Avatar
Old Trusty Old Trusty is offline
Old Trusty is starting off with a positive reputation.
Yeah ^ what Brad said!
Old 08-20-2014, 02:08 AM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
I agree with these post!^^^^^
BTW, sweet truck. Hope the black paint job on mine turns out that nice. Got a build thread on yours?
Old 08-20-2014, 08:58 AM
liftnw8z's Avatar
liftnw8z liftnw8z is online now
(CL) Team Brahma
liftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputation
Quote:
Have a look here
There's some good info in this thread. Will have to digest more in detail later as there are a lot of similarities with what he did and what I'm planning.
Old 08-20-2014, 08:48 PM
Build thread?
No sir, no build thread. Not sure how to go about that. That is the original paint job. Many years of that "expensive square can" liquid gold. I was told I was crazy for buying that wax for years but whos laughing now. It is showing some signs of oxidizing on the roof and hood and a tiny bubblehere or there over the rear wells. But for the most part, it shines like it always did.
On the lift thing. I spoke with a really nice guy at Atlas suspension in Cali this afternoon. I am seriously thinking about going with his reverse shackle 4 or 6" kit. Very nice and knowledgeable man. This Atlas group was referred by Deaver springs.
Thanks guys and I'll look into the build thread thing.
Oh yeah, one more thing. Before I do anything, I need to address some surface rust on the underside rear. A couple years in North Dakota and Wisconsin got under the undercoating I think. I think I want to take the bed off to get it all and do it right. Any suggestions on how to go about and what to use?
Thanks again guys.
Sid
Old 08-21-2014, 04:32 PM
Pappawheely's Avatar
Pappawheely Pappawheely is offline
Pappawheely is gaining momentum as a positive member of FTE.Pappawheely is gaining momentum as a positive member of FTE.
I recommend Atlas Spring. They did custom leaves for my 92 f350 and I could not be happier. I am running 37X12.5-17 Falken Wildpeaks and Trailready beadlocks. My truck rides 100X better than stock. They will match the springs to the weight of your truck.
Old 08-21-2014, 05:14 PM
ghanson's Avatar
ghanson ghanson is offline
ghanson is gaining momentum as a positive member of FTE.ghanson is gaining momentum as a positive member of FTE.
Quote:
I second this! A quality set of leaf springs can't be beat. I'm currently saving up for a full set from Atlas. They use multiple thinner leaves to give it a much smoother ride than the thick 2 leaf springs that come stock (just like Deavers). Also, they offer different styles if you're looking for flex, payload, or a mix of both.
BTW Pappawheely, that is one GORGEOUS truck!
Old 08-21-2014, 06:15 PM
Just to clarify..
A RSK will make a truck ride better than any leaf spring you want to install. It allows the spring to move in its NATURAL motion. Unlike the stock design
Old 08-21-2014, 07:48 PM
RSK?
Mr. Brad,
Can you tell me what an RSK is? Pete at Atlas spring recommended a reverse shackle kit with his leaf springs. He tells me the ride is much improved for my type of truck. I am really wanting to lift it more than it is stock right now. I have currently 33's on it right now. I'd like to jump up a couple sizes in tires and lift the truck to accommodate WITHOUT trimming sheetmetal. I need to see some trucks with 4 and 6 inch lifts so i know what it is I'm looking at. I can google all day long 4 and 6" lifted 96 f350's. I get some awesome pics, but have no idea the size of lift or tires on their trucks.
Mr. Brad, are you saying the reverse shackle from atlas is NOT the way to lift my truck? Also, before that purchase, I need to remove the bed and completely clean up the surface rust on the under rear. I need to see what all is involved with removing my bed.
Thanks for any inputs.
Sid
Old 08-21-2014, 09:13 PM
Since you didn't read the link I posted
Reverese Sackle Kit
And the STOCK SuperDuty springs will ride better than the OBS length springs
Old 08-21-2014, 10:21 PM
Quote:
Originally Posted by cityjack View Post
Mr. Brad,
Sid
I have a reverse shackle kit from SORD too.
Old 08-22-2014, 07:39 PM
RSK and a lift
Evening guys,
Mr. wheeley, how large is the lift with your reverse shackle kit? Did you have to cut any sheetmetal with the 37's you have on there? Your guys' acronyms are killing me. OBS? help a new guy out will you? I want to lift the truck and be able to put larger than 35's on the truck, WITHOUT cutting metal. I understand the reverse shackle is a better ride.
All input is appreciated.
Thanks
Sid
Old 08-22-2014, 08:15 PM
Old Body Style
Old 08-22-2014, 08:47 PM
Evening guys,
Thanks
Sid
LMAO, oops sorry. Yes OBS = old body style, like our trucks. SORD has two shackle reversal kits; a 3 inch and a 5 inch. I have the 3 inch kit and flat springs in front. That gave me a 5 inch lift that clears the 37's. I did some fender trimming before I lifted it to clear the 37's but the 3 inch and springs should clear 37's without trimming.
Here is a link to a story about how my springs were made. http://www.fourwheeler.com/how-to/su...-springs-work/
99-04 super duty leaf spring lift in 71 f250 crazed87bronco 1967 - 1972 F-100 & Larger F-Series Trucks 464 03-11-2016 02:20 AM
Best options for lifting or leveling my 2004 ford 250?? truckguymn92 Brakes, Steering, Suspension, Tires, & Wheels 1 03-10-2016 04:47 AM
Mildly lifted F-350: Toning down the bounce? SheepShanker 1999 to 2016 Super Duty 25 06-15-2015 11:49 AM
96' F350 crew cab 4x4 XLT cityjack Brakes, Steering, Suspension, Tires, & Wheels 1 08-25-2014 03:38 AM
Need a favor/Cummins swappers grinnergetter 1973 - 1979 F-100 & Larger F-Series Trucks 17 10-16-2012 09:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
