Steering wheel lights out
Franklin, hoping you can help me out. my steering wheel lights r out and need to know which wire runs power to those. also the led in my headlight switch is very dim.I checked the wiring and all the wires check out with high 11's and high 12 volts.i checked the volts at the led in the switch and it read 2.18 v.i have another light switch from the salvage yard and the same thing. which wire powers that light. also, the light only comes on when the key is in the on position or back for accessory. if i just turn the lights on it wont lite, only with key in ignition in those positions. truck is a 2000 f350 xlt dually thanks, Rick
The steering wheel illumination comes from the same lightblue/red that feeds all the dash lights. There should be a lightblue/red that comes up behind the steering wheel, and there is a sliding contact that several wires go through, so the wheel can turn, but the power can still transfer through. Be careful, the airbag wiring goes through this same contact piece. Usually you will have a airbag fault also if there is a problem with this sliding contact.
Same with the headlight switch. This is where the lightblue/red wire originates from that feeds all the dash illumination. There is a module inside the switch that varies the voltage on this circuit for dimming. As the circuit comes out of the switch on the lightblue/red the light for the headlight switch is tied into this same wire. Looking at the diagrams, there is a ground(black wire) leaving the switch for this circuit. It could be a poor ground causing just that light not to work correctly.
I rechecked the blue/red trace wire and it's putting out 2 volts less than the other wires. 11.28 with truck on and 10.09 with truck off. The wire going to the steering wheel is the same ,volt wise , but only is hot when ignition is on and the lights don't work and the led in the switch is dim. I'm thinking it's something in the ignition? I had an alarm put in a few years back and maybe they screwed up something somewhere? Also, the bottom brown wire that goes into the plug gets real hot and the plastic is brown instead of white. Thanks
