Battery terminal - Ford Truck Enthusiasts Forums
Battery terminal
Old 08-19-2014, 07:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Question Battery terminal
Why is happening this to the battery positive terminal, in the drivers side??
Old 08-19-2014, 08:00 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Is that the bolt that goes in it, or did you put a longer on in it ?
Old 08-19-2014, 08:08 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Question
Quote:
I really dont know, maybe the PO changed it, IDK; I only IIRC added one terminal there for the upgraded front lights. Are you thinking, as I am, about different materials and make a chemistry reaction?
Old 08-19-2014, 08:20 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
So you added the one red wire with the yellow insulation on the crimp? The one behind it is also aftermarket. I've found that the best place to "stack" ring terminals for additional circuits is the junction point on the starter relay. Not sure if that's what's causing your build-up, though.
And at 750 CCA, your batteries are a bit undersized. Supposed to be 850 CCA each, minimum. Maybe down there it's less of an issue.
Old 08-19-2014, 08:33 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Arrow
Yes as I said, IIRC I did, I dont know about the other one, like you said is aftermaket. For junction point you mean the bolt that receive the battery terminal in the starter relay? Maybe I should change to there that ring terminal.
About the batteries CCA I bought the best here in Mexico, and they are 8 years old and still working.
Old 08-19-2014, 08:42 PM
Quote:
Yes, that's what I had in mind.
About the batteries CCA I bought the best here in Mexico, and they are 8 years old and still working. [/QUOTE] Ah, the joys of never having to start the truck truly COLD.....
Old 08-19-2014, 09:10 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Talking
Ah, the joys of never having to start the truck truly COLD..... [/QUOTE]
Thats rigth
PS and here they (AZ) dont sell duralast GOLD.
Old 08-19-2014, 09:28 PM
fordpride's Avatar
That's what I'm thinking Jose
Old 08-20-2014, 09:13 AM
RÖENTGEEP's Avatar
FOREIGN GURU
Question
Im going to change the ring terminals to the starter junction, and the bolt, but what kind (material) of bolt I should put there? Nickel?
Old 08-20-2014, 07:19 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
make a mix of baking soda and hot water.
pour it over the battery terminal slowly, and wait for it to stop bubbling. then pour some more over it.
do this until everything is clean.
once clean, dry everything real good, and spray the terminal and all connections with clear coat, or any paint you have laying around.
this will help to keep the corrosion from happening again.
Old 08-20-2014, 07:49 PM
richdawg's Avatar
richdawg richdawg is offline
richdawg has a good reputation on FTE.richdawg has a good reputation on FTE.
I have seen + post/connections look like this before, and recently on one of my cars with an older battery. What causes it? IDK I googled it and the fallowing answer sounds similar to your problem.
"Why does the positive battery terminal keep corroding?
I recently had this happen to my 2007 ford fusion it was under warranty so i took it to the dealer and they said it was caused from the battery leaking at the Post's,they replaced the battery and the positive cable and i have not had any other problems with it since".
Here are some pics of my battery posts, pos and neg. The batts were new last fall/winter, as you can see i have extra cables similar to yours that run a power amp for my cb radio. I had the same set up with my old batteries with no problems. My reason for connecting directly to the posts, was i always thought it best to get power directly form the source.
Old 08-20-2014, 08:10 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Arrow
Tom,
I did the first part till was clean but, following your comment, Im going to spray the terminal with clear coat. I think is a good idea.
Rich,
Maybe the issue is caused from the battery leaking at the Post's, remember that they are almost 8 years old
Thanks for your input gentlemen
Old 08-20-2014, 08:14 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Exclamation
BTW I dont discard the chemistry reaction at all.
Replacement battery terminal queen of spades 1999 - 2003 7.3L Power Stroke Diesel 29 01-21-2016 07:50 AM
What size wrench for Battery terminal KDAVID1 6.0L Power Stroke Diesel 14 07-04-2015 08:43 PM
Battery cable Terminals hotweekend 1999 to 2016 Super Duty 3 05-29-2015 07:49 PM
Looking for a double battery positive terminal Landscape Doctor 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-14-2015 10:17 AM
Battery terminal cleaning question nnero 2009 - 2014 F150 7 08-04-2014 06:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
