got blinkers, running lights, no brake lights
You should have power to one side of the switch from the fuse. Use a jumper across both pins to see if your brake lights come on. Wires to the pedal switch break sometimes, there's a replacement connector with pigtails available. Pedal switches last for a long time and seldom need replacement.
manuelolivo is starting off with a positive reputation.
Sounds to me like:
Check also for the signal light - four way flasher switch. I had the same problem where tail lights and brake lights some times worked and others won't light up , and it ended up being worn out connectors inside the switch. The four ways flasher switch wasn't traveling all the way when switched on and off and was interrupting the functions of the lights.
Hope you found the fault...
Sounds to me like:
russell christy
09-26-2013 06:27 AM
michaelbrainardatwor
08-07-2008 08:19 AM
74f100
05-27-2004 10:12 AM
