duel carb question - Ford Truck Enthusiasts Forums
duel carb question
Old 08-19-2014, 06:46 PM
FlatheadNewby FlatheadNewby is offline
FlatheadNewby is starting off with a positive reputation.
duel carb question
I'm wanting to put duel strombergs on my flatty and really like the look of the mechanical fuel pump. I was wondering will the pump keep up, also will crab distributor work for setup, read somewhere should go with electronic but would like to keep the crab.
Old 08-29-2014, 01:09 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
I don't know if the original pump will keep up or not. I installed a rotary pump with my fuel tank relocation and a pressure regulator for my original two barrel carb.
What I did to preserve the original look was to take the original fuel pump apart and gut it. Remove the valves and all linkage. Then I made a sheet metal diaphragm and assembled the fuel pump using the metal diaphragm to keep the fuel contained in the upper chamber only. This way the fuel from the rotary pump goes through the fuel filter bowl on the original pump and through the original pump ant on yo the carb. It looks original and if you didn't tell anyone no one would know it wasn't stock. I've included a picture.
Old 02-10-2015, 09:57 PM
green53's Avatar
green53 green53 is offline
green53 is gaining momentum as a positive member of FTE.
you will be fine with the stock fuel pump as strombergs like 2.5 to 3 PSI, you may need a pressure valve to decrease the fuel pressure to avoid pushing gas through the needle and seats. You don't want flooded carbs or worse gas leaking out carbs near the generator with the brushes sparking!!!! Cheers.
edelbrock 1826 thunder series carb sanders92 1978 - 1996 Big Bronco 1 03-07-2016 07:01 PM
GTG for April 25th. fire240 Delaware Chapter 31 04-29-2015 12:22 PM
flat head resealing bernette 1947 and Older Ford Trucks 2 04-25-2015 09:00 AM
Rear Wiper Relays 985crabs 1997-2006 Expedition & Navigator 15 03-24-2015 04:08 PM
point less distributer bernette 1947 and Older Ford Trucks 9 04-01-2014 12:10 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
