1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 5.4 trans issues
Old 08-19-2014, 04:31 PM
osmond.mark's Avatar
osmond.mark
osmond.mark is offline
My plow truck has been sitting all summer. It's a 2001 f250 5.4l gas. I went to move it tonight and all was fine in forward but in reverse it's like it's slipping at first. Give it a little rev and it's like it's slips for a second and then takes off as normal. When you stop it's the same thing over.
Last winter reverse was fine. I do have an issue with it won't come out of 2nd. I only have 1st and 2nd gear but I believe that is a totally different problem and probably electrical related.
Thanks for any help!
Old 08-19-2014, 05:21 PM
Leon82's Avatar
Leon82
Leon82 is offline
Hows the fluid level?
Old 08-19-2014, 05:26 PM
osmond.mark
I will check tomorrow. It was fine when put up. And no signs of a leak where it was sitting though.
Old 08-20-2014, 09:10 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Hmmmm.....the direct clutch is used for 3rd gear AND reverse. And neither 3rd gear nor reverse are working properly. Maybe it isn't a separate issue, and probably it isn't electrical.
Old 08-20-2014, 09:26 AM
osmond.mark
It's not that 3rd is slipping it's just won't shift to 3rd.
Reverse works fine it's just you have to rev it to get moving. Seems like it slips for a few seconds but then takes off as normal.
Old 08-20-2014, 06:18 PM
osmond.mark
Just an update. The level did appear to be low so I added a little fluid. It seems to be getting better the more it's driven around. Hopefully with a little more time it will work good again. A vechicle that's laid up does absolutely no good for it!
It's going in the shop for some body work tonight so when I get it back I will check into this some more. Thanks for the help everyone.
Old 08-21-2014, 08:29 AM
Mark Kovalsky
Right. Both of these symptoms point to a failed direct clutch.
T.Cody
07-29-2017 11:05 PM
chrisaw0811
03-03-2013 08:53 PM
joelswork
17
05-14-2011 10:07 PM
boggerted
04-14-2010 09:03 PM
cjbronco
1978 - 1996 Big Bronco
01-24-2005 06:42 PM
Quick Reply: F250 5.4 trans issues
