315's and 3.55 gears? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-19-2014, 04:07 PM
TexasDiesel97 TexasDiesel97 is offline
TexasDiesel97 is starting off with a positive reputation.
Looking to get new tires for my truck soon, wanted to get an opinion on running 315/75R16 tires. I currently run 285/75R16 tires and they work well. I am a bit concerned about my towing capabilities as I do tow up to 10,000 pounds behind my truck and sometimes a 7,000 pound travel trailer (I sometimes go wheeling and to the beach as well). What is y'all's thoughts, stay with what I got or is up sizing okay?
Old 08-19-2014, 04:30 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Is it an Auto or a Manual truck?
I run the 315/75/R16 BFG All Terrains with 4.10 gears and an automatic transmission and I love it!
I have heard people who run the 3.55 with 35" tires it can be lugged down when towing heavy weight.
It also depends on what sort of power upgrades you have done. If you create enough power then I wouldn't be worried about being lugged down.
Old 08-19-2014, 06:49 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I wouldn't do it. Mine had 305's with 3.55's when I bought it and towing is not real good if its fairly stock. If its been upgraded much, you'll be smoking more yet until your rpm's get up. It's just not a good combination to tow 10k. 265's would be better for you, but I sure wouldn't go taller than the 285's. JMO of course.
Old 08-19-2014, 09:17 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
NO, you will hate it.
I tow exclusively with my truck and it is 4.10 and 315s. I could not even begin to imagine towing with 3.55s
Old 08-19-2014, 09:31 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Brad or you running 315 on stock width wheels ?
Cause on the stock steels I was wearing out the centers on 315's at 35psi
Old 08-20-2014, 12:46 AM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
If the truck is an auto with out mods to motor or tranny do not do it, you'll regret it.. I had an automatic 97 cclb w 35's and 3.55s and it hated towing, great unloaded on the highway but absolutely the worst combo for towing.. Like 427 said 265s would be the best for your setup... If if you have a stick you might able to get away w 33s but even at that you'd still be pretty tall...
Old 08-20-2014, 05:21 AM
When it was a dually, yes
Old 08-20-2014, 09:20 AM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Im running 4.10's with 325 tires which are basically 35-36" tires. Its pushing it, 315 may be better for me, couldnt imagine 3.55 gears tho
Old 08-20-2014, 12:18 PM
Well my truck is an auto, it has a stage 2 rebuild from Marshall engines. I have a tw chip, 6637 intake and a 3"dp to 4" exhaust. I suspect y'all are right and I prolly will just stick to 285's till I can do a front axel swap and 4.10 gears.
Old 08-20-2014, 01:30 PM
nossliw's Avatar
nossliw nossliw is offline
nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.
Since we are on the topic of 35's, I have been trying to find a 35x10.50 for a long time...the only one I think out there is an INterco SSR and no way in hell will that work. Anybody able to find anything close? Currently on 285's and would like to go up a size, I simply don't want a 12.50.
Old 08-20-2014, 02:00 PM
Quote:
Do you have 16" or 16.5" rims?
Old 08-20-2014, 02:01 PM
jchosler's Avatar
I dont know any off the top of my head, they def are not that common. A 35x10.50 is a tall skinny tire. i know when they start getting taller there also designed wider to spread that much volume and load on more surface area esp with us being 3/4 ton and bigger.
Old 08-20-2014, 02:02 PM
nossliw's Avatar
Quote:
I have 16's
Old 08-20-2014, 02:13 PM
I have 16's
Coker has some narrow stuff, I'm not sure if any are radials tho...
Coker Tire - Buy Vintage Tires and Wheels
Old 08-20-2014, 02:19 PM
nossliw's Avatar
hmmm. Looks like I'll be sticking to 12.50s :-) at least to get a 10ply
tire size help needed Quigles4 1987 - 1996 F150 & Larger F-Series Trucks 1 09-15-2015 10:44 PM
315/75r16 at stock height? Pigman54 1999 - 2003 7.3L Power Stroke Diesel 9 03-31-2014 01:18 PM
Considering a gear swap??? Splatts 1994.5 - 1997 7.3L Power Stroke Diesel 25 12-03-2013 03:27 PM
Dually tire seperation Splatts 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-23-2012 02:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
