315's and 3.55 gears? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-20-2014, 02:24 PM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by nossliw View Post
hmmm. Looks like I'll be sticking to 12.50s :-) at least to get a 10ply
I've seen these on dual rear wheel trucks up my way.. The 35x12.5x16 has a mounted width of 9.5" TrXus MT | Interco Tire
Supposedly they go good on the road..
FYI I had a set of SSRs on my 97 cclb, they were pretty quiet, think I got around 30k out of them. I sold them with enough lug to get a sticker..
Old 08-20-2014, 03:53 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
FWIW, I have 3.55 and currently have 265s on stock 16" rims and the odometer reads about 5% slow according to my phone GPS. For two weeks I was running 35s on 16.5" wheels. I noticed no difference between the two but did not GPS the 35s. The 35s measured an actual 33".
I'm not towing and have little plans to do so for now. I did put in a BTS valve body.
I think a lot of it depends on how you intend to use and drive the truck.
LeoJr's Avatar
Double post...
Old 08-20-2014, 04:08 PM
I agree w you Leo, for a daily driver, no towing, with frequent highway driving 35s are actually nice w 3.55s.. You can run 80 +/- and still keep the revs at 2k or under... Boy do they suck to tow with tho...
Old 08-20-2014, 05:01 PM
LeoJr's Avatar
I wonder what the cost of a gear vendor under drive costs versus re gearing both ends...my research project for the night....
Edited to add: about three grand. Never mind.
Old 09-11-2014, 02:07 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
I ran 305/70R16s with 3.55s and an auto. I was able to pull around a 25ft boat without any issues & 4x4 also without any issues. I know you asked about 315s but the info might help give some idea as to what to expect.
Old 09-11-2014, 08:00 AM
LeoJr's Avatar
I recently ran 37s for a few weeks. They speedometer read about 15% slow according to the phone gps. With the 3.55 gears it really wan't too bad but having an auto trans is what really makes it usable. I habitually turned off the OD unless I was on the highway. I suspect the truck would have acted better if I reprogramed the PSOM (speedometer) but I'll do that when I've committed to a tire size.
Unless you are driving at speeds the torque converter is locked (45 mph and up?) you put more heat into the transmission. I used my aeroforce gauge and noticed it ran about 10 degrees hotter. A trans cooler would be an absolute must if you were towing or heavily loaded. I have a trans cooler I will be mounting in the future.
Old 09-11-2014, 08:21 AM
I use to always turn off my OD when I started the truck; I'd engage it manually otherwise it shifted in to soon for the 35/3.55 combo and my liking.
tire size help needed Quigles4 1987 - 1996 F150 & Larger F-Series Trucks 1 09-15-2015 10:44 PM
315/75r16 at stock height? Pigman54 1999 - 2003 7.3L Power Stroke Diesel 9 03-31-2014 01:18 PM
Considering a gear swap??? Splatts 1994.5 - 1997 7.3L Power Stroke Diesel 25 12-03-2013 03:27 PM
Dually tire seperation Splatts 1994.5 - 1997 7.3L Power Stroke Diesel 5 01-23-2012 02:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
