centrifuge blueprint - Ford Truck Enthusiasts Forums
Old 08-19-2014, 04:01 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
Anybody have one handy?
Im interested in building one from scratch.
Mostly interested in rotor designs. Not too worried about the housing. Thinking i will try the pressure cooker idea for the housing/body of the unit.
So yeah... again, mostly just need an idea to start from on the rotor before i stuff some material in a lathe.
If it works out to a pretty quick cut time with little to no problems, i might be able to knock out more and sell them cheap. 1k+ for a fuge is retarded.
If it pans out... would there be any interest from you guys?
Old 08-30-2014, 03:33 AM
Orpackrat Orpackrat is offline
Orpackrat is starting off with a positive reputation.
I have a wvo designs raw power and a simple centrifuge, same basic design, a bowl with a curved and open partial lid...
Just got to keep it balenced.
Old 08-30-2014, 03:46 AM
I've been tempted to build a centrifuge that operates entirely on 12vdc. A mobile processor for production on the go like long road trips....
Old 08-30-2014, 09:10 AM
MNBen's Avatar
MNBen MNBen is offline
MNBen is starting off with a positive reputation.
I have a large pressure cooker and a motor. I would be interested in a less expensive fuge if one was available.
Old 08-30-2014, 06:46 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Old 01-01-2015, 01:18 AM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
I really like this design myself:
Simple Centrifuge ...putting a centrifuge in every garage!
If you watch one of the videos, there's a blueprint/cutaway view of it; you could easily whip up some actual blueprints with that and measuring the picture(Hint: the overall stock size used for that appears to be 9" diameter)
I'm intending to do this myself one of these days, but I've got to get some 9" aluminum cyl myself.
Old 01-13-2015, 04:05 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
I was using an old cream seperator for awhile, but it was just to slow and gravity is still free last I checked, so I quit.
Old 01-16-2015, 09:49 AM
timmyboy76's Avatar
i did the gravity too, but you'd be amazed on what the c.f. pulls out. looks like black tar thats being extracted from the rotor. And the oil being spun was an amber gold color too
Old 02-10-2015, 08:05 PM
finitetime finitetime is offline
finitetime is starting off with a positive reputation.
I've been using gravity but have been considering building my own centrifuge. I think I will go the Raw Power PoBoy kit for $250.
Raw Power Centrifuge - PoBoy Kit
From there website:
If you REALLY want to build your own centrifuge,this is the key piece:
Includes:
-Rotor
-Seal and clamp
-Parts list for centrifuge
Includes: -Machined Rotor, -Clamp Bushing for 5/8" Dia motor shaft (no key), 5/8" Shaft Collar, 5/8" Dia Viton shaft seal.
Instructions to build an enclosure and basic layout are available here: Download Designs
5 x 5 rotors Torrance00 1973 - 1979 F-100 & Larger F-Series Trucks 33 08-05-2015 11:09 AM
unable to remove rear passenger brake rotor!! Andy's Beast 1999 - 2003 7.3L Power Stroke Diesel 6 06-06-2015 09:48 AM
1997 Explorer Rear Axle Orientation oldracerjones Explorer, Sport Trac, Mountaineer & Aviator 6 05-17-2015 01:32 AM
Braking system upgrades/maintenance for 99-07 trucks the_auto_tech 6.0L Power Stroke Diesel 31 01-20-2015 02:27 PM
Any interest in a Meeting? Bill W Arizona Chapter 42 09-10-2010 03:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
