Early 99 7.3
No, I don't believe it will just drop in I think there needs to be some modification to make it work. Someone will chime for the exact reason why, but have you looked into the rebuild kit from Riffraff. I just rebuilt mine and was pretty easy.
Here is the link.
Garrett GTP38 Journal Bearing Rebuild Kit - Riffraff Diesel Performance
Here is the link.
If it is truely a E99 van turbo build date of 1998 and has a 4 bolt compressor housing cover and the same size compressor outlet as a E99 Fseries turbo then I think it will. If it is all the above I do believe you can bolt it up. If it has the larger compressor outlet or a 5 bolt housing cover it will NOT work! It will not mount to the syder.
EMD_DRIVER
02-05-2011 10:52 PM
