Replace side mirror insturctions
Could anyone provide me with instructions for replacing my 2014 F150 side mirrors? I want to switch to the towing mirrors. I am looking at the ones from 1A Auto and Ford's OEM. The ones from 1A are less expensive, but does anyone know how the quality compares to the ones from Ford?
Need help guys, there has to be a link somewhere (which I haven't found) that shows or tells how to do this???
It's super easy. Two 6mm screws at the bottom of the door, then there are 2 8mm screws, one behind the door handle (remove small black cover carefully with screwdriver). And one under the door handle (need to remove small grey peice with screw driver). Then the door panel can be lifted up and pulled outwards to expose the mirrors.
To remove the mirrors simply pull up the plastic cover over the mirror nuts, take off the 3 nuts (10mm I think), unplug the wire harness. And pull the mirrors out and replace.
Check YouTube I know there are videos on there.
As for replacing just the glass, there are some clips behind the mirror glass, not sure on their location or what the best way to do it is.
Killer RC
24
05-13-2015 05:24 PM
BigSix1
07-17-2009 04:16 AM
