97 F250 front fit dually rims - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-19-2014, 11:06 AM
Mi-Cyn's Avatar
Mi-Cyn Mi-Cyn is offline
Mi-Cyn is starting off with a positive reputation.
I have 97 F250 7.3L turbo diesel 2WD Dually, I want to use the same rims that fit on the back to fit the front, I have found an F350 front rotor/hub that has fit the dually rims, will this rotor/hub fit my F250?
Duralast/Brake Rotor - Front (54039) | 1997 Ford F350 1 ton P/U 2WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
Thanks for the help.
Old 08-19-2014, 09:23 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
yes. You put them in in place of your rotor and the bud wheel will bolt right on
Old 08-20-2014, 07:31 AM
Mi-Cyn's Avatar
Thanks
Old 08-26-2014, 09:53 AM
Mi-Cyn's Avatar
Swapped the front rotor/hub f250 to F350 dually, worked perfected,
Left Front Rotor rubbing on Caliper Bracket DAPtomey 1999 to 2016 Super Duty 2 11-28-2016 02:16 PM
Front rotor/hub assembly for 1974 f350 1 ton srw Ricster Large Truck 0 11-28-2016 09:00 AM
NEW F-250/350 & Excursion Front Brake Rotor/Hub Tractionless Ford Truck Parts for Sale 1 03-13-2016 04:30 PM
Urgent!!! roghoge 1999 - 2003 7.3L Power Stroke Diesel 8 07-23-2015 07:09 PM
Single Mass 13" Flywheel/Clutch kit for $300 hateme 1994.5 - 1997 7.3L Power Stroke Diesel 17 10-19-2014 10:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
