1997 f250 ccsb 4x4 issue - Ford Truck Enthusiasts Forums
Old 08-19-2014, 08:30 AM
PaulAM PaulAM is offline
PaulAM is starting off with a positive reputation.
I recently bought a 250 and I went to try the 4x4, and one its hard to get it to engage, and if I can get it to engage I can go about 50 yards before it makes a clank noise and the 4x4 disengages. The only way I was able to keep the 4x4 working was if I held the shifter in place. Does anyone know what the problem is and how to fix it?
Old 08-19-2014, 08:55 AM
madMatador78's Avatar
madMatador78 madMatador78 is offline
madMatador78 is gaining momentum as a positive member of FTE.
Welcome to FTE!
Sounds to me like your linkage is binding up and not letting it engage as far as it should.
I would get underneath the truck and spray all that linkage down real good with some penetrating oil and try and free it up. Don't pull to hard, the linkages are known to break if forced.
EDIT: Do you have manual or automatic hubs?
Old 08-19-2014, 11:20 AM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
When it disengages, does the t-case shifter actually move? Does it go back to 2HI, or to neutral?
Have you tried 4LO?
Old 08-19-2014, 09:06 PM
I can't get it even get it to 4lo but I have manul hubs, and yes it moves forward
2003 F250 4x4 ESOF sometimes engages, sometimes wont engage chris2888 1999 to 2016 Super Duty 5 01-25-2016 09:15 AM
99 explorer 4x4 will not engage inabind15 Explorer, Sport Trac, Mountaineer & Aviator 0 01-08-2016 09:34 AM
2009 F250 Powerstroke 4x4 auto won't engage. Troy_455 1999 to 2016 Super Duty 9 07-13-2015 08:37 AM
04 Explorer will not move while in gear when in 2WD or 4H hdel Clutch, Transmission, Differential, Axle & Transfer Case 3 01-15-2015 12:39 PM
2002 F-250 4X4 Transfer case relays RBlanton 1999 to 2016 Super Duty 2 01-13-2014 02:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
