Headlight high beam shutoff
Do the headlights stay off or do they come back on?
The headlight switch has a circuit breaker built into it. It's the type that resets automatically.
This is a common failure on old switches. The headlights go out and after a few seconds, they come back on.
If the circuit breaker is tripping, you also need to check the circuit for any shorts, bare wires, cracked insulation, pinched wires, etc. The headlight switch could be bad, but it might be the circuit breaker is doing it's job.
As Mike said, you need to determine if the headlights are shutting off because the breaker is tripping. Look downstream for any obvious pinched or frayed insulation. Don't go spending your $20 on a new switch just yet.
Any chance you had the front clip off or did a body swap recently? Over half of these threads start the exact same way, and the OP conveniently forgot to mention that half of the truck's sheet metal has been moved around.
That description sounds like a bad switch. Unless you know the trick, they can be a bit of a pain to remove. The switch's **** and shaft are released by a button on top of the switch. You depress the button and pull the **** and shaft out.
Eddillard79
07-26-2015 02:41 PM
