Bed wood finishing/sealing?
Hey guys, I am about to send my bed out for paint and I am wondering about the best way to treat the underside of the bed wood. Is it better to simply water seal it or should I use undercoating like I did under my fenders and cab? I am in AZ so we don't have to put up with much snow or rain, but who knows where we will end up with this truck. Could be anywhere. So wondering what is the best way to preserve and protect the underside of the bed wood...
Thanks, Tyler
Thanks, Tyler
From what I can tell, the original hardwood under layer in my '49 was untreated. Appears to have held up in a climate with four seasons. Unless AZ suddenly gets as humid as a swamp, I wouldn't do more than apply whatever finish you are putting on the top.
Sounds like you are eagerly nearing the finish of your build.
If the bed floor is solid planks, then fourtyniner is correct use the same finish (I recommend 100% pure Tung oil, I have posted several times about this, do an advanced search on my user name.) equally on all 6 sides. Clear film finishes, i.e. typical hardware store products, are all destroyed in short order by UV which will leave it a mess. You never want to use a water tight sealant like undercoating or bed liner on wood, especially on the bottom. The wood has to be allowed to breathe to prevent mold and milldew (dry rot).
Here is some info. on Tung Oil.
Tung Oil - Woodwork Details
___________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness - 3 pedals and a 5 speed "
OK, thanks everybody! AX if I understand you correctly (I read many of you posts on this topic) you recommend staying away from varnishes all together, just go with tung oil? And also, I gather you're not a fan of oak because of its poor performance with UV and its moisture wicking properties, is that right? I have oak (it came with my new bed) but I am thinking of switching to cherry.
Let me correct and clarify my issues with oak: Oak is a very open grained porous wood, so it takes a lot of finish to seal the large exposed cells. Most people get tired of applying finish long before the grain is filled, leaving it able to absorb water which expands the cells. The expansion will cause any film finish to develop fine cracks or crazing, and lifting the finish, letting in even more moisture. Oak's high tannin content when in contact with moisture forms a very acidic solution. (Traditionally a solution made from oak bark boiled in water to extract the tannin was used to "tan" leather, Tanning refers to the darkening and change to the leather in contact with the tannic acid solution) Tannin when exposed to air and UV causes the poly finish to deteriorate and the oak wood to turn black.
Your choice of (American black, not sour or Brazilian etc) cherry wood is a good one. Cherry heartwood is a dense fine grain wood that takes a pure tung oil finishing beautifully and when exposed to UV slowly darkens to the beautifully rich reddish brown color we woodworkers know and love. (PLEASE don't stain it, be patient and let it color naturally.) However if you apply a film finish like poly varnish the darkening will stop dead in it's tracks and it will never develop it's beauty. Cherry sapwood finishes to a pale yellow color which can give a beautiful contrast to the heartwood.
Correct IF you are using 100% pure tung oil, NOT "tung oil finish" such as sold by Watco and others in the big box DIY and paint stores/departments. "Tung oil finish" is nothing more than polyurethane varnish thinned with solvent and containing a minimal amount of tung oil, just enough to be able to put it on the label. A marketing ploy used to sell a smaller volume of polyurethane varnish cut with much cheaper mineral spirits (as much as 50%!) for a premium price than charged for the same amount of uncut varnish! Pure tung oil is sold by specialty stores catering to the professional/serious hobbyist fine woodworker. It is expensive since it is pressed from the nuts of the Tung tree rather than being mixed up from chemicals in a vat in a factory, (just like fine extra virgin olive oil is more expensive than cooking spray), but it is a much better product to finish hardwoods with. Pure tung oil sells for about 20.00 a quart at stores like Woodcraft, Woodworker's Supply, and Klingspore, but it does go a long way. Let me correct and clarify my issues with oak: Oak is a very open grained porous wood, so it takes a lot of finish to seal the large exposed cells. Most people get tired of applying finish long before the grain is filled, leaving it able to absorb water which expands the cells. The expansion will cause any film finish to develop fine cracks or crazing, and lifting the finish, letting in even more moisture. Oak's high tannin content when in contact with moisture forms a very acidic solution. (Traditionally a solution made from oak bark boiled in water to extract the tannin was used to "tan" leather, Tanning refers to the darkening and change to the leather in contact with the tannic acid solution) Tannin when exposed to air and UV causes the poly finish to deteriorate and the oak wood to turn black. Your choice of (American black, not sour or Brazilian etc) cherry wood is a good one. Cherry heartwood is a dense fine grain wood that takes a pure tung oil finishing beautifully and when exposed to UV slowly darkens to the beautifully rich reddish brown color we woodworkers know and love. (PLEASE don't stain it, be patient and let it color naturally.) However if you apply a film finish like poly varnish the darkening will stop dead in it's tracks and it will never develop it's beauty. Cherry sapwood finishes to a pale yellow color which can give a beautiful contrast to the heartwood.
Thanks for your advice. Yeah I've met AX (Chuck). He and I had some BBQ and a beer a couple years ago. We went and looked at his panel truck and his shop. He has skills in lots of other crafts too and is a wealth of knowledge. Dude has skills!! T
If you are talking about treating the underside, per your OP, how much UV is it really going to see? What it will see is 90wt gear oil slung off the pinion seal, grease flung off the U-joints, and likely a fair amount of heat from the exhaust where they jump over the axle. I wouldn't spend too much time or money on it.
Hey Chuck, I am looking into getting the cherry here in the next few days at my local Woodcraft store. Incidentally, the price they quoted me didn't seem too bad: $180. Anyway, I was discussing the tung oil approach with the guy at the store and his only reservation about using %100 tung oil was that it has no UV inhibitors. Above, you explain the UV exposure helps darken the cherry to a beautiful tone, but does it also damage the wood over time? Obviously UV is a huge issue out here in AZ, while rain is less so. It does rain, especially in the winter and during summer thunderstorm season, but not like what you get in your neck of the woods. He was suggesting I consider a product called Outdoor Oil (General Finishes Outdoor Oil is an exterior-rated oil. | General Finishes) which I'm sure you're aware is a linseed oil with UV inhibitors. Evidently, like tung oil, it is not a varnish and you can reapply it in the future without stripping/sanding. What is your take on that product and the UV inhibitor issue? Thanks! Tyler
Since it is "How they were done", I am planning on painting my bed here in Phoenix. There was a thread about it earlier and it contained a link to a company that tested finishes. What I got put of it was use POR15 as a primer.
Wood Finish Testing - Testing of different wood finish products
Dan Sokol
Dan Sokol
