a/c compressor won't kick on - Ford Truck Enthusiasts Forums
Old 08-19-2014, 12:22 AM
cjdmcgarry cjdmcgarry is offline
cjdmcgarry is starting off with a positive reputation.
I've been troubleshooting the a/c on my 1991 F250 XLT Lariat 4x2 for a few days now. The blower is working, but is not pushing any air through the vents most likely due to a clogged evaporator (its covered in dirt and may be a little damaged so its not allowing air to pass through). Additionally the compressor clutch is not engaging. I read the wires going to the compressor and am not getting any voltage. I tried jumping the accumulator to see if it was a low charge keeping the compressor from coming on and had no luck with the power issue. This leads me to believe that the a/c switch on the console isn't engaging to send power to the system. Any ideas?
Old 08-19-2014, 11:12 AM
Encho's Avatar
Encho Encho is online now
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
You already ruled out the accumulator, so yes, focus on the console and the compressor wiring itself. Replace the evaporator too.
Dumb question: Did you check any related fuses?.
A/C Compressor On With Heat kountzecobra 1968-2013 Full Size Vans 10 02-22-2016 09:38 AM
A/C puzzler..at least to me Gamma505 1999 to 2016 Super Duty 7 05-18-2015 07:25 AM
07 Expedition EL A/C Blowing Warm Air martyshel 2007 - 2014 Expedition & Navigator 2 05-07-2015 11:44 PM
A/C Compressor issues hmdocbean 1997 - 2003 F150 5 07-30-2014 11:16 PM
A/C Compressor Wont Disengage rla337 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-09-2013 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
