No Brake Boost on 1990 f250 xlt lariat gasser - Ford Truck Enthusiasts Forums
Old 08-18-2014, 10:22 PM
Le Juggernaught Le Juggernaught is offline
Le Juggernaught is starting off with a positive reputation.
So i just took over a title for my buddies 1990 f250 xlt lariat gasser thats been sitting in his back yard. I was inspecting the brakes and noticed the truck brakes work but only when it reaches the floor with no boost. Engine running or not there is not resistance to assist in braking. I did notice and air hissing leak sound coming from under the steering column in the cab as if a diaphram or seal had torn. My guess is if I had a blown seal or diaphram in the firewall mounted brake booster. I did bleed the brakes and saw no external brake fluid leaks coming from the lines, calipers or master cylinder. So my guess is a bad brake booster. Does anyone else have any advice or ideas what it could be and what should be replaced?
Old 08-18-2014, 11:00 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Vacuum leak under the dash..... Do these trucks have a cruise control purge valve under the dash. You know, to let out vacuum from the vacuum servo to close the throttle.
As far as no assistance, booster must be bad. It's not unheard of. But check the hose and check valve to see if they are plugged.
If your brakes were good, assisted or not, the pedal shouldn't go to the floor. Double check for leaks, and maybe look for a swelling brake hose when you push the brakes. Possibly need to bleed brakes more or the master is also bad and not building pressure.
Old 08-18-2014, 11:09 PM
ill check out the swelling hose. as far as the the leak under the dash it is only when i push down the brake pedal pushing the the rod through the cylinder causing a forced air release as if an o ring or seal has ripped and pushing it back out. almost as if its preventing it from applying the pressure it needs to activate the booster resulting in just applying the brakes mechanically. I hope I made sense somewhat.
Old 08-18-2014, 11:10 PM
UNTAMND's Avatar
Yup. That also. Leaking booster you could probably hear inside cause of the gasket.
Check it out and let us know.
Old 08-18-2014, 11:20 PM
will do. dont have time tonight but ill get back to you guys either tomorrow or wednsday
Old 08-25-2014, 01:34 PM
So i ended up replacing the brake booster and then also realized I needed to get new rotors and pads. But it still is not working as I had hoped, yet the braking is alot better. So my last thought is the master cylinder with an internal leak.
Brake Swapping Questions grinnergetter 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-27-2015 09:20 PM
Remote brake booster question GB SISSON 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 03-13-2014 09:12 PM
Brake Pedal slowly moving to floor? EvoDawg Brakes, Steering, Suspension, Tires, & Wheels 14 01-19-2013 02:55 PM
FORD F-250 Brake pedal sucked! Ford5.8XLT88 1987 - 1996 F150 & Larger F-Series Trucks 26 07-21-2011 04:29 PM
68 F250 brake booster swap- need tech advice MY68F250 1967 - 1972 F-100 & Larger F-Series Trucks 25 04-07-2008 08:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
