Can my fuel regulator be weak? - Ford Truck Enthusiasts Forums
Old 08-18-2014, 11:00 PM
kevin206's Avatar
kevin206 kevin206 is offline
kevin206 is starting off with a positive reputation.
1989 F-250 5.8L FI
I know that the fuel pressure regulator usually fails because of a busted diaphragm, but can it just become weak?
My fuel pressure is sitting at about 27psi at idle. It goes up a few psi when I pull the vacuum line. I clamped my return line at the tank and the fuel pressure fluctuated between 80psi and 100psi. BTW, the truck ran and idled great at the high pressure.
The symptoms I currently have are low pressure at the fuel test port, rough idle, slight stumble while accelerating. I have replaced my in-tank low pressure pump, replaced fuel filters, repaired kinked lines. I have bypassed the frame mounted dual function reservoir for the time being.
Old 08-18-2014, 11:22 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
remember its a fuel pressure regulator. did you check the pressure when you kick it during a crank key on engine off rest pressure. how a bout a MIL try pulling codes and the only thing the line crimp will do is flood the engine
Old 08-19-2014, 12:05 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Yes they wear out. It's a spring and a needle valve. Could also have some debris on the seat causing low pressure.
They are cheap. Just buy a new one. Idle pressure with vacuum disconnected should be 39-42 or so. Vacuum connected will lower it some.
terrible fuel problems please help mhobbs 1987 - 1996 F150 & Larger F-Series Trucks 5 06-21-2015 04:24 PM
C53 MOTORHOME 1996 32000 miles EAKOCH Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 12-17-2014 11:46 AM
Fuel pressure question musicars 1987 - 1996 F150 & Larger F-Series Trucks 2 10-27-2014 04:48 PM
P0171 and P0174 + fuel pressure JR_F350 1987 - 1996 F150 & Larger F-Series Trucks 10 07-14-2012 08:07 PM
3 new fuel pumps still low pressure! oreodog 1987 - 1996 F150 & Larger F-Series Trucks 2 02-17-2012 04:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
