Stiff clutch - Ford Truck Enthusiasts Forums
Stiff clutch
Old 08-18-2014, 10:30 PM
Snowturtle Snowturtle is offline
Snowturtle is starting off with a positive reputation.
Stiff clutch
Ever since I bought my '97 F250 8 years ago, the clutch has been hard to depress. It works fine, it just takes a strong leg to use it. When I got a new clutch a few years ago, I was sure a new pressure plate would fix the problem but, no, it stayed the same. Then when I replaced my motor a couple of years ago, I installed a new slave cylinder - still stiff. Today I put in a new master cylinder and it hasn't changed. It has never bothered me but now I'm trying to sell the truck and people want to know what's wrong with the clutch. So….what's wrong with my clutch?
Old 08-19-2014, 12:09 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Nothing. Stop being a Sally.
The only thing is if the input shaft bearing retainer is worn and causing the throw out bearing to not slide on it freely.
There's not much going on there to cause resistance. You've replaced everything, so it just pushes harder than some.
Old 08-19-2014, 12:26 AM
I agree. It works fine so I guess that's just the way it is. I need to find a buyer that's not a Sally!
Old 08-19-2014, 10:16 AM
BigSix1 BigSix1 is offline
BigSix1 is gaining momentum as a positive member of FTE.BigSix1 is gaining momentum as a positive member of FTE.
Subscribed.
Need Help-Failing Clutch or Hydraulics? loudoun 1999 - 2003 7.3L Power Stroke Diesel 2 06-24-2015 09:20 PM
Help! Clutch failing CaptainFacePunch Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 03-22-2015 11:21 PM
Weird clutch Richard.Parker 1997 - 2003 F150 0 08-30-2014 01:17 AM
hydraulic clutch not disengaging problems... hayden01 Clutch, Transmission, Differential, Axle & Transfer Case 18 08-06-2014 10:01 PM
My Clutch Pedal Won't Engage My Clutch. xc4life_nemo 1987 - 1996 F150 & Larger F-Series Trucks 2 11-09-2006 07:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
